Question about Audiovox KLV3913 12 in. LCD TV/DVD Combo
How to open the back cover of the tv? - Audiovox KLV3913 12 in. LCD TV/DVD Combo
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Will open by removing front bezel on lcd side
Posted on Apr 28, 2013
Pleace show me kenstar tv code
you will get your code at the back of your tv or in the box of the tv or after opening the back cover of the tv
Feb 05, 2012 | Televison & Video
My Samsung TV HLS4288W shuts off by itself. When I turn it on it repeats with the same, shuts off. I have to repeat this process several times before the TV finally stays on.
There's a loose connection in the power supply of your television.Try to fix this problem.If you want to do the repair,just open the back cover of your TV and look the power supply.Try to resolder the board of the power supply and check the connector to power supply from the board supply.You can power on the televisions while the back cover is open to see that the power supply is working. Thanks!!
Aug 21, 2011 | Samsung Televison & Video
Tv was new. tv fell over. tv not working
Hi.Try to check the fuse located at the back of the board near the ac cord.You need to open the back cover to see the fuse inside.Unplug first before you remove the cover,replace the same value of fuse.
Jul 05, 2011 | Philips Televison & Video
Have older rca tv...shut off with sleep mode...will not turn back on...tried unplugging...didn't work...now cannot get it to turn on
Try to open the back cover of your TV.Then check the fuse of your TV near the out let cord of your tv.check if the fuse is blowned or open.Replace new fuse with the same ampere.Then power on again the tv.
Jul 01, 2011 | Televison & Video
No sound no picture 3 blinking lights
Has the TV been opened before. If it has check if you have installed the back cover because the TV checks for this.
If it has never been opened just take th back cover off and carefully clean the fans at the bottom of the set. Make sure your TV is unplugged first !!! To remove the back cover it should only be around 8 screws so easy to do , make sure you donot touch anything else. Be gentle with the blades too. Switch on the TV only after the cover has been set back onto the set or not the TV will still give you an error and may not start up normally. Best would be to call a Samsung repair center and they will send someone over , and if your set is in warranty he replace any offending parts for free too.
Mar 04, 2011 | Samsung HLT-5075S Television
I was wathing tv when my light started flickering then the tv turned off now it wont turn back on please help
Hello, This is a sudden high voltage, it will require opening the television to check faulty component. First check for fuses in the printed circuit board and if found replace with same current rating. Also check other component such as the power transistor, resistor, rectifier with a multimeter set at ohms range
May 20, 2010 | Televison & Video
I removed all screws from the back of my lcd tv to replace minor part and i still cannot pry open the back cover. Seems to be stuck inside the middle.
U sure all the screws are remove.I have taken out many tvs and monitors,all way open.Recheck the middle might have some screws might miss or some covering might cover it.
Jan 13, 2010 | Samsung LN46A650 46 in. LCD HDTV
Hi my name is matt, i took the the back cover off and saw that there is an arc of electricty thats constant and makes a popping sound at the back of the picture tube, also noticed a spark on the main board...
hi ,matt
pls don' t open TV back cover it your self becose inside the back cover very High Voltage [more then 29 KV] EHT is working and she is wery dengures in tv on condition
your tv problum is EHT or CRT base so pls check and replace this spear with qualify technicean.
i think CRT Base in focus pin is sperked and pictur on screen is out of focus .Replace CRT Base with NEW . it 's not Expanciv spear.
Oct 30, 2009 | Zenith C36V23 36" TV
I turned the tv off the other night with the remote just like i always do got up next morning to turn it on it won't come on I have tried everything unplugging it pushing the power button on the tv instead...
Good day sir/maam, chances are you tv's switching power supply circuit has gone bad, you may try the following.
  1. open the back cover and locate the fuse, check if the thin wire is intact, (unplug the unit before opening the back cover) replace and test if the fuse blew up. test again.
  2. if the fuse is intact. replace the cover.
At this point. you have no choice but to call your dealer or repair man for service.
Oct 08, 2009 | Panasonic CT-36SX31 36" TV
Tried to turn tv on this morning no power at all tried changing fuse used power cable on another tv
Open up your TV cover housing, and look for the fuse. If it is busted,
have it replaced. Put the cover/housing back in place and power up
your TV set. Send us an e-mail and let us know.
Sep 26, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Audiovox KLV3913 12 in. LCD TV/DVD Combo Logo
49 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
