Drivers for accomodata 120 hard drive
I can't get my accomodata hard drive to work. The light is on and it recognizes it on my with windows 7 but when i try to save a word file on it says "you can't save on here? How do i get it to work? Thank you.
  • 244 Answers
SOURCE: driver problem
Hi Vicient,
I have the following questions to evaluate the problem.
1) What's the port your harddrive supported? Is it standart IDE cable or SATA.
I have a hardrive utility software that can detect and access any type of harddrive but you need install it at running windows.
Please email diazphi@gmail.com and dont forget to used the subject "Driver Problem" if sound interesting for you.
Sincerely,
Philip
Posted on Oct 31, 2007
SOURCE: Windows Vista Don't recognize my usb hard discs
last guest your a f u c k i n g a s s h o l e..i have the same problem with vista nad no one has an answer...
Posted on Oct 28, 2008
  • 109 Answers
SOURCE: Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Posted on Feb 06, 2010
  • 825 Answers
SOURCE: computer wont recognize external hard drive
try to format the external HDD using command prompt..... type "cmd" in start & search box and hit enter... command prompt will be opened... Now type "format X:" where X=your external hdd drive letter.... if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
Posted on Apr 20, 2010
yammy_alf
  • 666 Answers
SOURCE: windows 7 won't recognize lacie 500 gb hard drive
let it windows 7 format your lacie 500. and check for permission.
Posted on May 02, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
WD 1200BEVS
you can pull out the hard drive from box and connect it directly with computer see if it can recognized it, can not install drive can be due to problem with the disk FW or Hardware.
try to listen the drive carefully, is there any abnormal noise, beeps ??
hope it helps.
Apr 11, 2014 | Western Digital Scorpio WD1200BEVS 120 GB...
Simpletech external hard drive not workin on windows 7
Windows 7 seems to have a lot of issues with external hard drives and any usb attached devices
Click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
the next works on usb data / pen drives im not sure on external hard drives
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
and i have found that leaving the a usb data drive plugged in and restarting my computer W7 my usb drive will work again (strange)
whatever works
hope it helps
Nov 05, 2012 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
Hi, my HD Fujitsu MHV2120AH is not working.
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
but if windows 7 and xp are not picking it up and are on separate computers a usb 2 or 3 card might not work
hope this helps
Mar 03, 2012 | Fujitsu (MHV2120AH) 120 GB Hard Drive
I'm running windows 7 (64bit) on a dell inspiron 1545. This Hitachi HTS542512K9SA00 120 GB SATA Hard Drive will come up as read. It seems its working. Yet I can't put anything on it. It just sits...
This can sometimes happen with new drives if the formatting isn't compatible. I would follow the instructions on this site: http://www.top-windows-tutorials.com/format-hard-drive.html to reformat.
Jul 18, 2011 | Hitachi HTS542512K9SA00 120 GB SATA Hard...
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
Solve Your SimpleTech (SP-U25/120G) 120 GB USB Hard Drive Blue lights are not on. Windows 7 does not recognize. I think driver is not installed. Pl advice
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 04, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Trying to connect my old Smartdisk USBFLB120 to my Toshiba Laptop with Windows 7 64 bit - can't get drive to recognize as drive - Lapop sees device but says it is unavailable
Change you usb port or replace the smartdisk's usb cable, probably the current one if broken. Also restart the pc whilst the smartdisk is connected. It shd be recognised now.
Jun 06, 2011 | SmartDisk FireLite USBFLB120 120 GB USB...
External drive not being recognized
check the cable or install the usb 2.0 driver then try again
Oct 06, 2009 | Computers & Internet
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
