Question about Radio Shack Pro-95 Handheld Scanner
Display Any fix for a blank display?
  • Anonymous Nov 08, 2007
    no display on pro 95 unit was dropped. tried reset button on left side of unit,Still no display. Does radio shack do repairs?
Try to set the contrast also did you drop the scanner it just went blank? give more details
Posted on Sep 10, 2007
  • kenster Nov 27, 2007
    yes as far as i know they do repairs probably a cracked pc board by the display section
SOURCE:
My nokia6300 display blank how can i fixed
There are two things related to this issue.The LCD might damage or the Display IC (filter) may damage.The only thing you can do is to change the LCD it is not so difficult.But if the ICs are damage you need to contact mobile repairing shop.Thanks for visiting fixya
Mar 23, 2012 | Nokia Cell Phones
The LED display on my AEG F88070IM is blank but
yes a new display is the most likely solution but check connections from input to lcd display card 1st..
Jan 04, 2010 | AEG 23 in. Favorit 88070IM Built-in...
Turn on phone it is ok then to blank then back to normal then blank
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Nov 19, 2009 | Nokia N81
Yamaha htr 5550 stereo receiver blank display. It
I would suggest a quick resoldering of the flatcable connectors, both on the display board as well as on the main board. That should fix the problem.
Oct 20, 2009 | Audio Players & Recorders
Nokia 6500 slide display 4900 problem
You need a T-6 Torx Skrewdriver to do the job.
Sep 16, 2009 | Nokia 6500 Slide Cellular Phone
My sony ericsson k510i screen blank white
ur display mus be changes there is no other way to fix this problem visit ur mobile expert to change ur display
Jul 08, 2009 | Sony Ericsson K510i Cellular Phone
TH-79A Blank screen. It works with "F-switch on" but then goes blank.
Happened to me too. It takes some disassembling!!!! Between the screen and the underlying circuit board is a rubber strip with conductive material throughout which provides ''ground' for the display. This rubber wears out over time, but the quick fix is to turn it a quarter after cleaning and treating the contact surface with 'contact spray'( sparsely!!).
Job requires steady hand and pincers.
May 28, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Display screen is blank
Panosonic KXTG5632 Screen is blank lights up but no numbers or info.phne works fine. Tried removing batt. Any sugestions
Thanks Bill
Jul 15, 2008 | Panasonic KX-TG5632 Phone
Blank white display on Nokia 3230
This is a major fault, screen gets blank white because of some problem in its display panel which is right behind the LCD screen. Rush to the nearest Nokia care centre and explain the problem to them.After the repair if you experience this problem again and your phone is within the warranty period you can demand a brand new box piece!
Sep 03, 2007 | Nokia 3230
Radio Shack Pro-95 Handheld Scanner Logo
52 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
xxxxxx xxx
Steve Allison
Steve Allison
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
