Question about Refrigerators
I have a GE GSS20IEMBWW side by side refrigerator and its sit in storage a few years I now have it back in the house and would like to change the water filter but I can't find it or a part number anywhere! Do they one??
  • 28 Answers
The replacement filter that you need for your GE refrigerator is a MWF filter. You can buy one here for a great price! http://www.freshwatersystems.com/p-2293-ge-mwf-replacement-refrigerator-water-filter.aspx
Posted on Jun 25, 2013
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Posted on Jul 29, 2007
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
22yooper
  • 828 Answers
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
I just moved the fridge to a new house and now the fridge and freezer won't get cold. It had been sitting in storage for over about a year, but worked perfectly before that.
Its possible that during storage a few things may have happened. There is a small fan under the back that keeps the compressor cool while running. Its possible that during moving something shifted or bent the fan area and its not running. Could also be a small critter built a nest in that same area stopping the fan from running. Without that fan--- the compressor will run a very short time and then cycle itself off on the heat safety when it gets too hot. It will keep short cycling off the heat overload until the fan runs again. It will not run long enough to get to proper temp. Just guessing but check this first.
Jun 18, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Gss20iembww
Find the light switch and make sure its not stuck, otherwise make sure the bulb is good.
Oct 26, 2013 | GE GSS20IEM Side by Side Refrigerator
I am trying to locate where the evaporator is on my GE side by side Model #GSS20IEMBWW
Behind the lower panel in the back of your freezer. Should be four screws to remove panel
Sep 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Dec 17, 2009 | GE Profile PSC25PSWSS Stainless Steel...
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Everything in freezer defrosted
the defrost has a timmer you mite have to chang it ok
May 14, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE gss20iembww wont end defrost cycle
yes replace heater tstat and back board
Mar 17, 2009 | Refrigerators
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
