Question about Sunbeam Carousel Rotisserie 4780
Parts I would like to know where I can get the black pan drive to purchase as it seems to be missing.
Truck will not move when shift into drive or reverse
your trans is toasted.drop your trans pan and look for black sediment in the bottom of the pan.you may even find some hard parts.
Feb 16, 2013 | 2001 Chevrolet Silverado 2500HD
Where does the wood chips need to be placed in the smoker?? I don't see a chip pan.
If you don't have the wood chip tray, you're sitting dead in water, at this point. The wood chip tray goes above the burner, below the water pan. If this is a brand new, just purchased smoker. Go back to where you purchased it or call the number in Owner's Manual for "Parts missing". If it's not brand new, you can purchase a smoker tray from Masterbuilt Customer Service 1.800.489.1581
Hope this helped you.
Jun 27, 2011 | Masterbuilt 20050106 Propane Smoker
Doesn't shift and shavings are in the pan.
Having owned a Trans Repair Shop years ago.
The rebuild manual---ATSG Manuals. Avail on their website or locally at a Trans Parts Supply house. Ask a local trans shop where they get there parts and get it there.
The fact you have shavings in the pan. The ONLY answer, is to pull the trans and take it to a Trans Shop and have it rebuilt. Then install a rebuilt converter and add a quart of fluid, before installing the converter.
You do what is called an over the counter. Your bring in the trans,they rebuild it in a couple days with all the latest updates. That is the least expensive way to go.
If they pull it, you surely will have things broken and pieces and parts missing when you get it back.
Aug 01, 2010 | 2000 Dodge Durango
The driveshaft falls out of the pan, even with paddle attached
The shaft is pressed into a bearing that is molded and stamped in the bottom of the pan. This bearing is sealed and allows the shaft and paddle to spin freely. The rest of the parts on the other end of the shaft interact with the motor on your machine. They do wear out and can not be repaired because the worn parts are not available individually.
Sorry to say there are no repairable parts, so it's time for a new bread pan. I don't know the brand of your machine so you can google or check ebay.
Hank
Sep 02, 2009 | West Bend 41052 Bread & Dough Maker
Package Contents
Not knowing exactly what is the name of the scope or the model-- do what I do-- go to a well stocked hardware store as most of the bolts and nuts are generic and can be purchased anywhere.
If you post the exact name and model-- maybe we can be more helpful.
Dec 13, 2008 | Optics
Zojirushi bread maker, BBCC-15, Baking Pan,Paddle drive seal
Hi terryhassler,
If you're looking for OEM parts, I'd go to
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If these don't pan-out (no pun intended, I think), the next place I'd start hunting is eBay.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 10, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Where can I get replacement parts for the BBCC-15? My keeper clip underneath the baking pan came off and is lost. It holds the wing clip that drives the kneeding blade in the pan.
Nov 22, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Missing hardware
I found this website for parts replacement I havent ordered yet but it gives you a list of baby cribs that they can service. www.productsamerica.com Hope its useful for you.
Nov 26, 2007 | Childesigns Carrollton Crib
Sunbeam Carousel Rotisserie 4780 Logo
47 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
