Question about Maxtor DiamondMax Plus D740X (6L020J1) 20 GB Hard Drive
Hardisk pro my maxtor hardisk is 40 GB but now it's shows 9 gb onely & its having bad sector how can i recover my 40 GB & bad sector please solve my proob..; sir
    Guru:
  • 120 Answers
You cannot recover bad sectors. Your disc is damaged and the drive has removed the bad sectors from being writable. You need to replace your hard drive asap before it breaks entirely. You're going to lose all your remaining data on the disc if you do not back it up immediately. Good luck, Peter
Posted on Aug 06, 2007
SOURCE:
Reboot while Formating Hard disk Maxtor diamondmax plus 9 120 gb ata/133 hdd Now my hard disk says it's damaged when i want to format it, can you sugges me some software to repair it ?
you could runthe chkdsk utility click start tpe cmd you are now in dos then type chkdsk/f/r to scan for and attemp to repair any bad files and bad sectors on your hard drive this will schedule to happen on restart of your computer another way of running the chkdsk utility click start click to open you should see your drive C: right click on select tools check now you will see two boxes tick in both again this will schedule to happen on restart if this is your primary hard drive with your operating system on it
hope this helps you
Jul 24, 2011 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
Hi ! My hard disk has problems. Being a slave, I turn on my pc I get "primary slave hardisk-SMART status bad backup and replace". once loaded the system (windows XP sp2) click "My...
Hi. This is a typical sign that your hard drive is experiencing a serious failure. I hope you have backup of the most important data on the hard drive. You can try to fix the hard drive using a tool like HDD Regenerator, but the results are not guaranteed. Your best option is to buy a new hard drive & restore the data from backups.
Jul 19, 2011 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
Drive very noisey when starts
are you sure its the drive and not the PSU power supply unit
if your hear it groan struggling to boot up it will be the PSU
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Dec 18, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
How can i recover bad sectors in my hdd drive using a startup disk?
Boot from the startup disk.
Run 'CHKDSK' with the '/F' (to "fix") option.
Oct 18, 2010 | Seagate 80GB Maxtor DiamondMax Plus20 Hard...
How to solve my maxtor 80gb hardisk bad sector problem
You can use LLF Low Level format Tool and make a low level format this take sveral minutes but the most probalby that can fix the problem
Mar 19, 2010 | Samsung (SP0411N) 40 GB Hard Drive
My hardisk 1tb only shows 500gb space, just bough it yessterday and i have installed it in port 0 and an other hardisk off 500 gb was installed on port 1 and when i go into my computer i only see both...
If you're using the original XP version it wasn't able to format the correct size of the hard drives. You need to find a version with Service Pack 2 and boot off that CD in order to format the correct size of the drives. You could also boot off a Vista installation CD and format the correct size.
Oct 01, 2009 | Western Digital 500GB My Book Pro-External...
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Bad cluster in hard disk
You must run scandisk utility in windows to fix problem. Go to C: drive >> properties >> tools >> choose error checking >> select automatically fix errors >> then start >>
If proplem persists you must format the C drive there may be less chance of bad sector recovery...
Or contact your manufacturer tech support if your hardisk in warramty period.
Jan 03, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Hard disk problem
your hard disk is developing bad sector (it will be dead) so better to backup your data
May 17, 2008 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Maxtor DiamondMax Plus D740X (6L020J1) 20 GB Hard Drive Logo
256 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
