Question about Fisher Price I Glide 4 Way Cradle Swing n Glider
Fisher Price Repair
Glide will only work for 2 full glide then the speed light will flash and the the unit will shut down
  • Sarah McCrossan May 02, 2013
    Mines doing something similar. I did some research and it turns out they're just really poorly made. :(
2 Suggested Answers
SOURCE: Camera will not stay on
I am not 100% sure but I think its actually related to the File system formated on the Camera and specifically the default block size and the physical number of Files that can be stored on the flash with it formated as default. When you look at the drive its a 64mb Flash formated in 16k blocks (crazy for a flash card of only 64mb) as this makes a ton of wasted space with a large number of files. I have experimented and it only appears that after you get a large number (>128) of files on the camera, things crash out. I suspect a poor implementation of the fat file system on reading/writing. Solution. At first I tried formating with 4kb blocks size but the camera reformats the drive after you format it. So end solution, keep your total pictures under about 119 and you will be fine, more then that and the file system on the camera barfs. Try it by erasing all files, you will be amazed at how you have your little camera back working again!
Posted on Mar 06, 2009
2003 Harley Davidson FLHTCUI Electra Glide Ultra Classic fuel gauge not working properly
Hi, Ed you could have a faulty sending unit or gauge, there could be a problem with your wiring. On models with the fuel gauge posing as a left-hand fuel cap, the gauge is a press fit do not try to unscrew it, simply apply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, the gauge should peg full, if not replace the gauge. With a test light check for power to the sending unit, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. If your fuel gauge registers the incorrect amount of fuel in the tank you can try bending the float arm the necessary amount up or down for a more accurate reading.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Testing Fuel Gauge Sending Unit Twin Forum Harley Davidson Forums
Harley Davidson Touring Workshop Service Repair Manual 2003 $10
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak to me personally absolutely "FREE"
Aug 27, 2017 | 2003 Harley Davidson FLHTCUI Electra Glide...
I need a front left leg for my fisher price swing n glider my little animals
They do not make parts for these so you are really out of luck here.
Sep 28, 2016 | Fisher Price Baby Swing N Glider
Oil light comes on and bike shuts down
Hi Anonymous, you could have an oil pressure sending unit going south on you or a broken or loose connection at said unit. They relatively inexpensive try replacing it. Good luck
Dec 27, 2013 | 2009 Harley Davidson FLHTCU Ultra Classic...
Samsung galaxy glide shuts off with full battery
his product is used for mobile phone screen specially. The inner material is dust-free wet strength paper imported from Franch. It will leave no trace and soft flocks after wipe the surface of screen.Mobile Phone Antibacterial Wipes
Feb 22, 2013 | Samsung Galaxy S Captivate Glide Sgh I927...
What should my oil pressure be at an idle on a 2000 Ultra Glide stock 1450
Hi Cowright7, start by checking oil level in tank and it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS.as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as nessary. Good luck
Jan 30, 2013 | 2000 Harley Davidson FLHTCUI Electra Glide...
2004 Dyna Super glide Fuel Gauge not working
Hi Anonymous, you could have a faulty sending unit or guage, there could be a problem with your wiring. On models with the fuel gauge posing as a left hand fuel cap the gauge is a press fit do not try to unscrew it, simply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, gauge should peg full, if not replace gauge. With a test light check for power to the sending unit, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Aug 03, 2012 | 2008 Harley Davidson FLHX Street Glide
I have a red key light and I have lost my turn signals and brake lights. I have running lights, head lights, cruise, spots and my security is working. The #2 fuse is blown, but when I change it it blows...
Sounds like bad brake light swich/sending unit.The one attached to master cyclinder.What happens to fuse if you turn ign. on,don't start engine,and hit brakes?Should bow fuse if switch is bad.
Mar 16, 2010 | 2005 Harley Davidson FLHT - FLHTI Electra...
Fisher Price I Glide 4 Way Cradle Swing n Glider Logo
41 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
