Question about Trendnet TEW 652BRP Wireless N Home Router (710931600599)
WAN light keeps blinking on my Wireless N Home Router and I cannot access the internet although I can access the router config page. This started just yesterday and before that the WAN light used to be continuous and sometimes blinking showing internet activity. Have tried resetting to its original, turning off for 15 seconds but no use. I use my internet cable connected to the wireless router. HELP !!
  • 7,627 Answers
How old is the device? May be time for a new device? Has there been any electrical storms? Power surges? Tried different connecting cables? When you reset the device, hold reset for 30 secs., release, wait for selftest, unplug device for 30 secs., plug in, wait for selftest, connect with a Ethernet cable, reconfigure SSID and Security Key.
Posted on Apr 30, 2013
  • Faisal Sidd Apr 30, 2013
    Thanks for your reply. The wifi is working fine now. I just unplugged the router for a couple of days and then plugged it in again and everything was back to normal.
4 Suggested Answers
  • 1768 Answers
SOURCE: were installing wireless internet at home and we
1. This error is related to the dialup modem
you will need to disable the dialup modem.
When setting up your router for the lan in the browser you will need to select "internet connect that is always on"
DNS should be on "automatically assign.
yes you can connect a switch to the router and the router will assign each port an IP address automatically.
If you are using the router wirelessly you will need to assign each device that is wireless via the MAC (Media Access Contro) number.
Check you router manual for details on how to set each device in the router by MAC address.
Basic instruction for multiple units set up in the router
Basic setup for multiple computer to go online:
1. power router off
2.connect all computers you want to connect.
3. start computers one at a time completely
4. check router for status light per computer to see if device is seen by router.
5. open web page to see if each computer is online.
7. Do ipconfig / release/renew if not connected.
Posted on Jun 22, 2010
  • 1584 Answers
SOURCE: Status and wlan litght flashing on router.
Have you enabled the wireless on the laptop first??
If so then you have to "join a network" in doing this you will be asked to type in a WEP key (Security key) to join the network. This key is the one you have secured (Or should have) secured the network with.
Posted on Oct 15, 2010
puertobori
  • 7733 Answers
SOURCE: How to reset Trendnet TEW 652BRP Wireless N Home
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Feb 12, 2011
My Zhone 1518-A1 modem-router keeps loosing internet connection although wifi connected. Is it normal that the internet led is blinking?
Its normal for the internet light to blink, it means that its having an activity.
Try accessing the modem GUI (graphic users interface) and then change the WEP key or security key , if the modem-router is not password protected then just reset it.
You can also change the power values on it
Hope this helps
Thanks
Dennis
Nov 04, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
I have a Belkin N wireless router, model F5D8236-4 v1. I am unable to connect to the internet using the router and I've even tried resetting the router with no luck. The "modem" light on the...
i have a belkin N wireless router model:F5D8236-4 v1 i have had it installed on my computer but it has since been wiped so there is no trace of me having it installed, since this i have moved home and ost the disk that came with it but i need to put the router back on due to my daughter having a laptop, how would i get the software for it if i have no disk?? please help!!!!!!!!!!!
Jan 07, 2011 | Belkin (F5D7231-4) Wireless Router
My dlink is set up and it shows on my wireless network but when i connect there is no internet comng through it just goes to a can not display this screen at this time page
Check the WAN light on the router -- if it is not lit, then your router is not connected correctly to your cable-modem or DSL-modem.
Start Internet Explorer, and access the web-server "built-in" to the router. Access the "settings" page, and check the "WAN" settings, to ensure that the router has received an IP-address from your Internet Service Provider.
Sep 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
Laptop shows wireless signal is available. DSL cable, all lights burn green on the router. Can access google, when I try to access a web address, the page will not load
in explorer > < tools > < internet options> <delete> all your temparary internet files.
now try accessing google.
On the router the only lights should be blinking are the connected ports Wan to the WWW the conneccted Lan ports to the intranet.
Powercycle the router and the reset button on the back.
Try a direct wire and see if the access to the net works.
Reconfigure the WIFI of the router by the instruction book
Aug 26, 2010 | NetGear WGR614 Wireless Router
My wireless router doesn't seem to be working although lights on it suggest otherwise. I unhooked the router cable that goes to the computer and hooked it into my modem in order to at least get some...
so the router has no control. Because you dont have any passw defined on wireless and everybody using your internet connection, and you pay the bill.
so to gain control, of your router , needs to have all internet provider config, on paper before reset router. there a reset button on the back. press for more than 5 sec, until the lights off\red. then go ie and type 192.168.1.1 then enter router site with user: is blank and passw: admin. go 1st wan config. with your internet provider config. and change all router passw even wireless (use WPA2 encription level) and save config on hd and reboots router.
Dec 29, 2009 | Linksys Wireless-G WRT54G Router
How to install and will this box allow my desktops(2 of them ) to both be connected to a wireless network?
There are 2 ways to setup Netgear
1. Setup Wizard (which guides you through a setup wizard)
2. Manual Configuration (you need to put all values in router manually)
Here we are not discussing Setup Wizard as Manual configuration is far much easier then auto configuration
To configure (config) Netgear we need to get into router page
To open router config page
1. Open Internet Explorer (Start>>all prog>>Internet Explorer)
2. Type in address bar 192.168.0.1
3. In username box type admin (where it says gateway 192.168.0.1 requires username & password)
4. In password box type password (word password itself)
After this you will find Netgear ADSL Wireless Router Setup page
Here we need to select Basic Settings (as shown below)
after this you will find next page as
Here in this page (Basic Settings Page)
Does your internet connection requires login, Select Yes
Select Encapculation as PPPoE
Login is Username as provided by your ISP
Password is your password for broadband connection as provided by your ISP
Keep Idle timeout as 0
after this simply press apply without changing anything else
Now We Need to click on ADSL Settings Page
Now on ADSL Setting Page We got only 3 options
Multiplexing Method Should be LLC-Based
VPI 0
VCI 35
now just press apply again
By this time your router should be only (you can check it by opening any website on Internet Explorer or by router status option on netgear page)
To Config Wireless
Click on Wireless Option (on left hand side blue panel)
It should display next page as
Here in this page
Wireless Network Name (SSID) Alpha-Numeric name which would be displayed as your wireless network name
Region Here Select Your Region
Channel: Select whichever channel give you best sighal (9, 11, 13 are recommended)
Keep the TIck on Enable Wireless Access Point
Keep the Tick on Allow Broadcast of Name (SSID)
Can Untick Wireless Isolation
Then Jump to Security Options
Select WPA-PSK (Wi-Fi Protected Access Pre Shared Key)
then in WPA-PSK Security Encryption type in anything of your own choice but alphabets and numbers both should be there and make it between 8 to 63 characters long.
WPA-PSK Security Encryption Key is your password for wireless network
Now Press Apply and your router is ready for wireless too
After doing this you can change MTU (Maximum Transmit Unit) size to 1400 from WAN Setup Option
You can find WAN Setup Option in same blue panel on left hand side of screen
Here you just need to change MTU to 1400 and need not to change any other setting
Now its all done and router is ready to send wireless signal to your system/laptop
Nov 26, 2009 | NetGear WGR614 Wireless Router
Internet loss
Hello
Check to link to find out that how your router should be connected
http://onlinehelp.verizon.net/consumer/bin/images/Fios/DLinkCabling_Updated.gif
Then unplug all the cables , power off the router for few minutes and replug all the cables again and restart the computer :
Check the link below to configure the router:
http://support.dlink.com/emulators/WBR2310/index.htm
Jaspreet
Apr 12, 2009 | Computers & Internet
Can't access Config Manager for Router - Zoom x6 5590
- Reset the router (10 seconds)
Access the configuration page (10.0.0.2)
or
Try to assign a static IP address to the computer (IP 10.0.0.52 Automated SubnetMask, Default gateway 10.0.0.2)
(Note: Make sure that your computer is physically connected to the LAN ports of the router and your modem is connected to the WAN or Internet port.)
Mar 08, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
Trendnet TEW 652BRP Wireless N Home Router (710931600599) Logo
186 people viewed this question
Top Trendnet Computers & Internet Experts
youbrokeit
Level 1 Expert
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
