Question about Archos Gmini XS 100 MP3 Player
Read error my archos will turn on but only to th welcome page with the brand name, all it does from them make a clicking noise after 2 miuntes give massage..read access error can't read from hard disk and turn off by it self and its a new i use it twice and i don't know what i have to do..i read every thing about it but notting help and when i bought doe'nt come with A C adapter....thank you if you can help me
    Novelist:
    Scholar:
  • 84 Answers
Test
Posted on Aug 07, 2007
  • 2 more comments
  • V. Chris Suehiro
    V. Chris Suehiro Aug 07, 2007
    Hi xxxmo...Your Archos Gmini XS 100 Mp3 Player is charged directly from your computer via USB. If you wish to buy the Optional AC Adapter, you may purchase it directly from Archos by clicking on this URL: http://www.archos.com/products/accessori...
    I suggest that you just visit your local Radio Shack or similar retailer and ask for assistance in purchasing a compatible AC Adapter.
    Did You buy this Player used? If yes, then you might have a faulty Hard Disk, in which case Only Archos may physically repair your Player.
    I will continue in the event that you purchased it New, and are just unfamiliar with it.
  • V. Chris Suehiro
    1) Begin by downloading the Drivers for your computer by clicking on this URL: http://www.archos.com/support/download/d...
    Once the page is loaded, scroll the page down until you see "USB". Click on "Download USB Drivers", and save it to a convenient location on your computer. I suggest you write the location down for easy reference, also ensure that you notate the File Name of the Download for easy reference.
    2) Next, turn on your Archos Player, and connect it to your computer using the USB Cable. Wait for prompts from your computer. If it asks for Drivers, direct it to the location and file/folder that you downloaded in the previous step. If your Player is recognized without any prompts, continue to step 3.
  • V. Chris Suehiro
    3) Click on this URL: http://www.archos.com/support/download/f...
    When the page has completed loading, scroll down the page to "Select Directly Your Product", and within that window, scroll down to, and select Gmini XS 100, and you will be redirected to the Firmware Update Download Page. Read the instructions on that page, and click on "Download Gmini XS 100 OS v 2.2.02"
    Once these steps are successfully completed, your Player and neccessary files for your computer to interact with your player will be up to date.
    If you need a manual for your player, you can download a copy by clicking on the following URL: http://www.archos.com/support/download/m...
    I hope you easily complete the above steps with a successful outcome. Please update your post with your progress or if you have any further questions...good luck my friend.
  • V. Chris Suehiro
    V. Chris Suehiro Aug 14, 2007
    Hi xxxmo...I presume that I have helped you in the proper operation and preparation of your Gmini XS 100 player since there is no indication otherwise...Please click on Solved to close this thread.
SOURCE:
My TH-15A starts making VERY loud crackling noises after a few minutes of being turned on. It does not matter if an XLR cable is plugged in or not, and the volume control does not change the volume of the...
buy a canister cold spray and spray on some active components if the noise begins You have a thermical failure in a component on the board can be faltering resistorcircuits or resoldering some active components.
May 08, 2016 | Mackie Tapco Th15a Thump Active...
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Turn on hangs on opening logo screen..center button="Read access error! Can't read from hard disk."
Possible causes and solutions
1 The hard drive within your player has failed, not uncommon and a real pain to fix for all but the real hands on techies. requires replacement hard disk likely same size required.
(unfortunately most likely problem) it will probably be accompanied by an unusual clicking noise coming from the player when held to your ear.
2 The hard drive within your player has become corrupt or something similar and requires formatting. Simple for any IT person to do. I'm no expert on this model and am too lazy to check but even holding down the reset button for 30 seconds or so may fix it.
Good luck hope i helped.
Jul 24, 2009 | Archos Gmini XS202 MP3 Player
Recovery code 101
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
May 27, 2009 | Archos 5 Internet Media Tablet
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
Apr 15, 2009 | Archos Internet Media Tablet MP3 Player
Archos 400 won't turn on (error code 3)
I hard tried the same thing to transfer a 6.7GB file to another computer.I had formated the drive as an NTFS drive. when i turned archos back on, it failed to turn on give me error code. but for some reason it asked me to do a recovery. I remember i had seen some recovery files in my archos device saved (zipped file packages). And when it was doing the recovery i noticed it was reading the zipped files for recovery purpose. After the recovery, i did not see the files anymore in the device. So if i do the same thing again (format as ntfs) i might not be able to recover it back again.
Mar 11, 2009 | Archos 404 Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
C) Computer
D) On the Archos 705:
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Hdd_recovery 2
LAST HOPE !!!
ERROR CODE 102!!!
I JUST FOUND OUT THAT I HAD THAT SAME PROBLEM TOO...AND I WAS ABOUT TO THROW IT AWAY OR GIVE IT TO MY WILD CAT TO PLAY WITH !!! BUT!!! HERE IS WHAT I DID FOR MY LAST HOPE IN SOLVING THIS PROBLEM...
FIRST HERE ARE THE DETAILED PROBLEMS I HAD...
*NO RECOGNITION OF MY ARCHOS IN MY PC...
*ERROR SCREEN..."SYSTEM DAMAGE...REPAIR? NO,REPAIR,FORMAT DISK"
*SELECTED ANY OF THE OPTIONS...SAME STUFF...BACK TO THE SCREEN...NEVER ENDING STORY...
OK...THIS IS WHAT I DID...
1 DOWNLOAD THE LATEST FIRM FROM WWW.ARCHOS.COM...TO YOUR PC !!
2.AFTER DOWNLOADING THE LATEST FIRM UPDATE TO YOUR PC... PLUG IN YOUR ARCHOS TO YOUR COMPUTER...
3 YOU WILL NOTICE THE ARCHOS IS NOT DETECTED AND YOU ARE IN YOUR SCREEN ERROR STILL...OK...TURN YOUR ARCHOS OFF BY CLICKING ON THE POWER BUTTON FOR ABOUT 5 SECONDS OR UNTIL IT TURNS OFF...(NOTHING ON THE SCREEN BUT BLACK...)
4. THEN...WE ARE ABOUT TO TURN IT ON AGAIN...BUT BEFORE THAT... LEAVE ONE FINGER ON YOUR TV/LCD BUTTON PRESSED !!! HERE IS THE SECRET...THEN TURN IT ON !! BUT...DO NOT LET THE TV/LCD BUTTON RELEASED !! IS LIKE YOUR ARE GOING TO PRESS BOTH OF THEM AT THE SAME TIME...AND WAIT FOR FURTHER INSTRUCTIONS...
5. THEN ANOTHER SCREEN WILL APPEAR..SORT OF LIKE...HDD RECOVERY 2...YOU MIGHT WANT TO UNFORTUNATELY FORMAT YOUR DISK...
6. ONCE IT TELLS YOU DONE ! DO NOT PRESS ANY BUTTON... THE PC WOULD NOW RECOGNIZE YOUR ARCHOS...AS A HARD DRIVE..ETC...
7. ONCE IS DETECTED BY YOUR PC...REMEMBER THE FILE YOU DOWNLOAD IT... DRAG IT DOWN TO YOUR ARCHOS..IN THE ROOT SECTION... THAT MEANS...IN NO FOLDERS INSIDE THE ARCHOS...BUT BY ITSELF...JUST LIKE ANY OTHER FILE IN A FLASHDRIVE IF YOU MAY...
8. THEN IT MIGHT ASK YOU AGAIN YOUR PC...YOU WANT TO FORMAT THIS DRIVE...JUST SAY YES....OK...WHATEVER... AND LET IT FORMAT...
9. FINALLY AFTER THE FORMAT SITUATION HAPPENS...YOUR ARCHOS WILL ACCEPT THE FILE...AND IT WILL BE DOWNLOADED AUTOMITICALLY...THEN REOPEN IT TO MAKE SURE IS THERE ALREADY...
10. FOR THE LAST STEP... ENJOY ! MY ARCHOS IS BACK TO NORMAL..IT REBOOT AND EVERYTHING IS FACTORY MADE...HOPE THIS WORK GUYS...AS FOR ME IT DID...
PS. PLEASE BE PATIENT ON THAT OPTION OF THE TV/LCD FOR IT MIGHT NOT WORK RIGHT AWAY...I TRY IT LIKE TWO TIMES BEFORE IT LET ME FORMAT EVERYTHING...BECAUSE YOU MIGHT GET ERROR MESSAGES LIKE..."MEDIA FAILED" ETC... JUST KEEP ON TRYING UNTIL IT ACCEPTS IT.. LET ME KNOW WHAT HAPPENED...
Jul 16, 2008 | Archos 605 WiFi Digital Media Player
HOW TO TURN THE WIFI ON THE ARCHOS 605 160GB
you need to buy the wifi plug in from the archos website, then unload it on to device
Jul 12, 2008 | Archos 605 WiFi Digital Media Player
Archos Gmini XS 100 MP3 Player Logo
205 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
