Question about Roundup Garden
Roundup Sprayer I can't get the sprayer to work at all. The batteries are working fine, because it runs but nothing comes out of the bottle.
  • 7,482 Answers
Hi Robert
Your pump probably needs priming.
Hold the triggger down and squeeze the bottle at the same time to create a pressure inside of the bottle of spray to prime the pump.
Bud
Posted on Apr 29, 2013
5 Suggested Answers
  • 15 Answers
SOURCE: Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
Posted on Apr 19, 2010
  • 12 Answers
SOURCE: I can't get the Roundup Professional Sprayer to
Put a little wd-40 or light oil down in the plunger shaft to get the leathers on the pump plunger to seal back against the cylinder wall. Work it a little and u will feel the pressure come back. Maybe some dish soap would work too if u like bubbles.
ballping
Posted on Jul 23, 2010
  • 4350 Answers
SOURCE: I have 2 sprayers one
Um what do you mean by not working. spray not killing weeds, or sprayer itself not working???
Sprayers clog up if not cleaned after each use, try cleaning the entire sprayer.
Posted on Oct 06, 2010
  • 4 Answers
SOURCE: how do you refill roundup
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Posted on May 05, 2011
Roundup battery propelled sprayer not working
Fix for electric spray wand not working that worked for me. Yes my wand would only spit out some foam, and nothing appeared to be clogged. The wand would spray just fine when I placed the siphon tube into a bucket of water.
Apparently what was happening was that the wand pump was creating a partial vacuum in the air tight canister, causing the electric pump to stop pumping. After all the battery pump is not all that powerful, just got a little foam. So I unscrewed the cap about one turn allowing replacement air into the canister and the wand started working.
Apr 06, 2013 | Garden
I've just been given a roundup 2 gallon sprayer. It seems to me the top should be removable to add the liquids but I can't figure it out and don't want to experiment to the point that I damage...
Howdy MMis971,The sprayer just needs to be pushed down by the handle as you turn counter clockwise. This can be made a little easier by unscrewing the nozzle where it connects to the tank to release any pressure built up by pumping.
Happy Gardening,Coach Dave
Sep 10, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Need a part for the sprayer. wasn't in the box the pipe with the sprayer end on it
Howdy g5483,Most reputable retailers' will either let you exchange the sprayer or get you the part. At The Home Depot we will gladly do either one to get you what you need.
Coach Dave
Aug 29, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
I have 2 sprayers one is the Roundup Professional Sprayer the other is the all in one sprayer from Roundup - neither of them are working - what am I to do?
Oct 06, 2010 | Roundup "" Weed & Grass Killer
ballping
Jul 15, 2010 | Roundup "" Weed & Grass Killer
Where do i find parts for a Roundup® Branded Tank Sprayer System.
Hi.
roundup branded tank parts/repair kits can be found here Amazon com roundup sprayer parts Just click on the link and choose one (which fits our budget, model etc...)
I hope this was helpful.
enjoy
Apr 18, 2009 | Garden
Garden Logo
175 people viewed this question
Top Roundup Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Roundup Garden Expert? Answer questions, earn points and help others
