Question about Dryers
Westinghouse LD505e has stopped working
It was working fine - a cycle had just about finished when I grabbed a piece of clothing out. The rest of the load was done, so I took it all out & put the next one in. When I hit start, all I got was 3 beeps. Nothing is making it start now! I let it rest, powered off, overnight; I have tried using something to activate the lock mechanism (while the door is open), and that didn't work; i even tried to spin the barrel and then quickly press start - also didn't work. Would like to know what it is - even if so I can at least tell the repair man!
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
manhandy
  • 146 Answers
SOURCE: After 3 years of reliable service, my LG DLG5988W
that is the safety switch probably need to be replaced. or make sure the door is closing all the way.
Posted on Jun 24, 2009
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
  • 40 Answers
SOURCE: westinghouse ld505e lights up for will not start
Try opening the door, spin the drum by hand, then qi\uickly close& press start. If this works, then the capacitor has failed. About $30, easy to replace.
Posted on Aug 17, 2010
richroth
  • 9472 Answers
SOURCE: GE dryer heavy duty 7 cycle, just finished drying
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Posted on Sep 28, 2011
Testimonial: "Richard was quick to response and extremely helpful. I ended up finding out the problem myself but richard was there with tons of help with the most minimum amount of details... THANK YOU AGAIN RICHARD"
How do you start a Westinghouse dryer Ld505E sensor dryer
if their is no start button push in on the main timer knob on some dryers
Dec 30, 2016 | Westinghouse Dryers
I have a Westinghouse Sensordry LD505E Dryer which has suddenly stopped heating up
Either your dryer vent is clogged or your heating element / ignition coil has failed. It's called a hot surface igniter
May 19, 2014 | Heating & Cooling
My Westinghouse LD505e suddenly stopped working during a drying cycle and it won't start. Would anyone be kind enough to guess what could be the problem and advise a solution. It's 4years old
Probably a blown fuse due to a heater element problem or maybe a bearing problem. I recently worked on one and did a movie which shows the fuse location and all:
More here
Oct 21, 2012 | White-Westinghouse Dryers
Westinghouse dryer ld505e on/off button wont stay on when l push it
If it has dampness sensor strips inside the machine they may be coated with dryer sheet wax or some other mess. Clean them with windex and retry. As the clothes rub against these sensors the dampness causes the dryness board to keep the machine a going. if no dampness is detected the dryer shuts down. Supposely to save power.
Jun 18, 2012 | Westinghouse Dryers
My whirlpool washer will start then stop before it reaches next cycle
1 Look at the drain hose to make sure it isn't kinked or clogged. If there is a piece of clothing lodged in there, clear away the hose from the pump and yank the clothing out.
  • 2 Take a look at the switch under the lid of the washing machine. If it doesn't click when you press it, it may be broken and the washer may stop during the drain cycle. Call a repairman to repair or replace the switch.
  • 3 Examine the clothes tub and the outer tub of the washer for anything that may be stuck in there.
  • 4 Open the main access panel of the washer and take out the large rubber hose connecting the pump to the lower part of the outer tub.
  • 5 Check to see if there is a piece of clothing stuck in there. If so, use a pair of needle-nose pliers to grab the clothing and pull it through the port. If it is difficult to reach, you will need to take out the agitator, the top part of the outer cylinder, and the interior tub to grab it. Unless you have special skills and tools, you may want to call a repairman.
  • 6 Inspect the pump for a clog or frozen pulley. To check if the pulley is broken or frozen, take the pump out and attempt to turn it manually with your hands. If it's stiff or appears frozen, install a new pump.
  • 7 Call a repairman if these steps don't work.
  • car transmissions
    Jun 12, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    User Manual Westinghouse LD505E
    go to www. fitness.manualsonline.com or www. retrevo.com or www. manualsfactory.com
    God bless you
    Jun 03, 2012 | Dryers
    My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
    May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
    Jun 12, 2011 | Westinghouse Washing Machines
    Rinse cycle does not work on washing machine
    Sounds like a belt or clutch issue. What is the make and model #?
    Nov 02, 2017 | Kenmore Washing Machines
    Westinghouse ld505e lights up for will not start
    Apr 02, 2009 | Dryers
    Dryers Logo
    42 people viewed this question
    Top Dryers Experts
