Question about Car Audio & Video
How to Reset SOUND MAGUS Car Amp
I have got the SOUND MAGUS Car Amp. This is in the ALARM State with the Red light on. This does not have any reset button, can you please suggest how to reset this.
  • 7 Answers
SOURCE: does not accept cd
I guess is your using a CD that was made from a blank one.. Try putting in a CD that you didn't burn.. and see if it works Some CD players does not place burnt CD's Hope i helped cya buddy
Posted on Aug 11, 2007
SOURCE: kenwood kac 859 amp
The amp will reset every time it's turned off. The red light flashing, instead of staying constant is a warning that one of the protection circuits are activated. If the amp is bridged wrong, it can do this. If the load impedance is too low, it can also do this... don't trust the speaker, it it says 4-ohm, it may actually be 3.8-ohm, which could cause a problem if two speakers are wired in parallel. If it's not getting enough power, it will turn off briefly, but will turn back on after a second. A capacitor is not necessary with this, just use 4 gauge cable and have a good battery... make sure the ground is good, that one is commonly ignored.
Posted on Aug 21, 2007
  • 113 Answers
SOURCE: how to reset my system?
disconect all power cables then short between terminals G&P G&R .a little spark but ok.try after 10min.
Posted on Aug 22, 2007
  • 631 Answers
SOURCE: Red light on my amp?
Does the amp power up normally if you disconnect the speaker wires from the speaker terminals of the amp?
It's never a good thing to blindly short across a power source.
Posted on May 22, 2008
  • 8 Answers
SOURCE: changed the battery. The alarm
Yes this is an Alarm issue that's why your vehicle is shutting down as soon as you press on the brake pedal. Is this an aftermarket alarm or stock alarm? Sounds like aftermarket alarm to me and if it is, the way fix this issue is as soon as you put the red n black terminal on the battery and the alarm goes off press your alarm key right away to turn it off. If this doesn't work put your key on the ignition after you have installed the battery and just put it on the "ON" position engine OFF then click on your alarm remote once again.
Posted on Sep 23, 2008
Red alarm light stays on all the time. How do I get rid of this problem. Car starts no problem.
Hi
reset the car alarm with the default reset button
this should return it back to its default setting and turn the light off
if its a factory fitted alarm consult manufacturers manuel
cheers
May 28, 2015 | Cars & Trucks
Reset anti theft system
Most alarms have a set way to reset go to dealer site on line and look for alarm reset for that car . Some set by cycling key three times, some have a reset code for door pad. Best of luck finding it.
Oct 08, 2017 | 1998 Ford Mustang
Alarm on my peugeot 406 hdi stopped working red light not flashing
Try battery in fob, might be low. U can try to disconnect car battery for 30 mins to see if it will reset unit.
Apr 05, 2013 | Cars & Trucks
Charged battery on 1997 Toyota Camry now immobilizer will not lock doors and car will not start
Here is the reset procedure:
1. Have the Valet Button in the OUT position. ( It is located on the dash panel left of the steering column)
2. Connect the battery - the alarm will sound.
3. Put the key in the ignition and turn to the ON position,
4. Push the Valet Button to the IN position.
The alarm will be reset, and the Valet Button will glow red.
Move the Valet Button to the OUT position again.
Repeat steps 3 & 4 and the Valet Button will become unlighted.
The car will start and everything will be fine.
Apr 20, 2012 | Toyota Camry Cars & Trucks
Idisconected my battery for water pump have after market radio didnt think it would be a prob. but it turns over and will not start it has built in alarm and indicator light flashes rapid is there a way...
Insert ignition key,turn forwards to run. Just till red lights & theft/alarm light goes on. Do not try to start or engage starter.Leave on till light stops flashing. It may take up to 10 minutes. Once light stops flashing turn key off. Then start car & let run for awhile.
Mar 21, 2011 | Pontiac Grand Prix Cars & Trucks
Alarm not working proper
try this. lock car door with key and hold key over for 30 secs then unlock the car with the remote holding button down for 30 secs.assuming the battery in the remote is okay...it should reset the alarm system.
Mar 08, 2010 | 2003 Ford F150 Regular Cab
Car wont start alarm light is blinking
yes factory alarm. there is a smal switch hiden under dasch board find it and turn the alarm of by reseting the boutton you can also open the driver side of car witt your keys
Dec 14, 2008 | 1994 Toyota Camry
Car Audio & Video Logo
193 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
