Question about Schwinn 12" Roadster Tricycle
Hi, I need a pedal pad for the pink roadster. Also need a replacement fringe on the handlebars.
How to make handlebars stay straight
It's good to be careful, but can't tell over the Internet what the problem might be. Try taking it apart to see if you can detect the problem, or have someone mechanically handy look at it (including a bike shop).
May 31, 2017 | Cycling
I have some picture distortion - pink fuzzy color where white should be (like on hockey ice). I'm trying to determine if the t-con board is to blame and if I might fix it easily
Hi Bill.
I don't see a specific model for your TV, but have owned a rear projector system before. There is usually a sub-menu where you can do fine alignment of the Red, Green, and Blue projectors to get rid of the pink fringe. There is generally a white crosshair at center screen where you can fine align the three colors to get rid of the fringing, and sometimes an advanced menu where there are crosses all over the screen that you can individually select and fine tune, (tweaking the different optical distortions of the individual projectors to overlap).
If the fringe is a big swath instead of a fine edge, or if a color is totally gone, then you may be talking power amp issues. For fine fringes, the adjustments usually work fine.
Hoping that helps!
D
Dec 18, 2015 | Televison & Video
My old fring account is not working. now i tried to download a new fring account, that time it is asking a mobile number. if i givemy mobile number there is message coming like this. "You have exceed
Mar 02, 2013 | Nokia C5 Cell Phone
On my daughter's Schwinn Roadster Tricycle the right pedal no longer is able to be secured to the spindle. Since the pedals and spindles don't have any threading I assumed there was an internal,...
I got a new Schwinn for my son and we went out today for the first time. Within 10 minutes the right pedal came off in the street. Having the same problem. Did you ever find a solution?
May 14, 2011 | Schwinn 12" Roadster Tricycle
Trying to find 3 layer or 5 layer fringe boots in UK. USA do not ship them to us
Hi, if you go onto ebay.com and type in ladies fringe boots you will get a wide selection of them, rangin from 1 layer fringe to about 6 layer fringe,
Hope this helps
Feb 18, 2011 | Minnetonka 3 Layer Fringe Boots Boots for...
Brake pad wear indicator light does not go off at the dash after changing rotors brake pads and the sensor in the front wheels all pads and rotors and the sensor is ok at rear. the vehicle has only 30000...
Did you change the sensor? if you did, do a battery reset (disconnect for 10 to 20 min.).
Obviously the wear sensor has made contact with the rotor and is already damaged. You're not even suppose to resuse the wear pad sensor if its worn or damaged anyways.The way how the sensor works is that it must make contact to the rotor to complete the wear pad light indicator circuit. There is no mentioning that he replaced the the wear pad sensor with a new one.
But if one did replaced the wear pad sensor and the wear pad indicator is lit up, the way to reset it is to leave the key on in ignition switch #2 or #1 for about 30sec. turn it off and its reset.
Its possible that you forgot to replace the brake light sensors. They are about 15 bucks, and have to be replaced in order for that light to turn off. You can either get them from the dealer where they'll likely charge you 3 times as much, or you can go to http://www.turnermotorsport.com and get them there.
You have to reset the light by leaving the ignition switch on position #2 for about 30 sec. turn off the ignition and start the engine up and see if it goes out. I recommend buying a new wear pad sensor as well because now light will lit up when you're way below spec (less than 3mm)
Also, you could try with this procedure for one E39: Turning off the Check Brake Linings warning on the Instrument Cluster...
- so you've just changed the brake pads on your E39, along with the wear sensors. The old sensor(s) needed replacement cause you waited a bit too long before changing the pads, and wore through the sensor(s), turning on the BRAKE light on the dash. But wait, the light is still on? But there's a new sensor installed... what gives?!
- there is a procedure required in order to turn off the light/warning. With the ignition off, step on and hold the brake pedal. Now, while holding the brake pedal down, turn on the ignition switch to position 2 (just before cranking). Hold the brake pedal until the BRAKE light is off. Tada, the warning is gone and reset.
NOTE: This procedure worked on a 2001 E46 325i. It took about 15-20 seconds, but it cleared out w/o having to unhook the battery.
Other details find in the Owners Manual 2006-BMW-Z4m-Roadster-Owner-Manual
Keep us updated.
Nov 04, 2010 | 2006 BMW Z4 Roadster
When taking pictures there is a color displacement of some sort. Leaves like bright purples and pinks shadowing images.It is worse in lighted areas, the more sunlight/bulb light the worse the coloring...
The term for an out-of-focus purple "ghost" image on a photograph is "Purple Fringing."
This is fairly common in Digital Photography.
In order to minimize instances of purple fringing you may incorporate the following:
Avoid shooting with big aperture (Small /f number) in high contrast compositions.
Avoid overexposing highlights (e.g. bright sky behind dark objects).
Shoot with a UV/Skylight Filter or a Circular Polarizing Filter. These protect the lens and also help to Get bluer skies and cut glare off reflective objects.
You could also use Post-processing to remove purple fringing by scaling the fringed color channel. This can be done in an image editor like Photoshop.
These suggestions will help in minimizing the instances of color displacement for you.
I will look forward to your feedback and positive rating.
Sep 11, 2010 | Sony Mavica MVC-CD500 Digital Camera
Schwinn 12" Roadster Tricycle Logo
23 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
