Question about Nexgrill 720-0234 (LP)
Does not reach high heat
The grill gets to 250 degrees but not any hotter
I have a natural gas hookup and my grill takes a long time to heaat up (15 minutes) and max degrees is 350 - 375. I found dust in the connection hose blew ut out. Also took grill apart and cleaned...
Unfortunately, that's the way it does on Natural Gas, in an outdoor environment. The reason being, Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Of course, on the plus side, you don't have to get tanks refilled. With that said, the thermometer on the grill may be faulty.
To test this theory, buy an inexpensive oven thermometer (the kind that can be placed on an oven rack) and place inside the grill, when you're preheating it with the lid closed. Once you grill thermometer reaches 350 degrees, open the grill hood and compare it the two temperature readings. If the oven thermometer is reading significantly higher, then you no the grill thermometer is faulty.
Hope this helps you get back up to temperature.
Mar 02, 2011 | Weber SPIRIT E-210 (NG)
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
Grill does not get hotter than 340 degrees
could be a bad regulator and or check for spider nests in the burner tube
Jun 20, 2010 | Weber Genesis Silver B Grill
The grill only reaches 200 degrees
PROBLEM
Barbecue temperature only
reaches 250° to 300° in the HIGH
position.
CHECK
The excess flow safety device,
which is part of the barbecue to
cylinder connection, may have
activated.
CURE
To reset the excess flow safety
device turn all burner control knobs
and the cylinder valve OFF.
Disconnect the regulator from the
cylinder. Turn burner control knobs to
HIGH. Wait at least 1 minute. Turn
burner control knobs OFF. Reconnect
the regulator to the cylinder. Turn
cylinder valve on slowly. Refer to
“Lighting Instructions”.
http://www.weber.com/manuals
Sep 07, 2009 | Weber Genesis Silver B Grill
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
Temp
Not sure on your climate.
But a Holland grill cooks cooler in the coller months and Hotter in the hotter months. This type of grill doesn't reach a very high setting approx: 400 degrees. It might reach higher temperatures in the hotter weather 450-475 degrees.
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Hollands are known for the slow cooking process and a Healthy way of cooking!
Apr 27, 2008 | Grilling
Nexgrill 720-0234 (LP) Logo
24 people viewed this question
Top Nexgrill Grilling Experts
80stech
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Nexgrill Grilling Expert? Answer questions, earn points and help others
