Question about Dryers
How can i locate a part number for this model i need a belt number
Need of a number for a replacement belt
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model is "this" model?
Posted on Apr 27, 2013
Model CX-NMT720 replace tape drive belt/belts
If the model does not appear in the PRB Pdf file then you will need to measure and subtract 5% and order those from a supplier. The service manual will not tell you how to put them in it just shows location. You need a speed test tape and frequency counter to set the speed anyway- best done by a Technician.
Nov 30, 2014 | Audio Players & Recorders
Where can i get a belt for a kenmore dryer model # 122-00
do you have the old belt??? If so, take it to an automotive parts store and buy a belt the same size. If not take it to an appliance store that sells parts... and see if they can match it. If the old belt has any numbers on it that will be a big help. Have you tried Amazon or Ebay....??? I bet I can find a belt within a hour or two.
Sep 06, 2014 | Kenmore Dryers
I would like to locate a cutting deck belt for my husqvarn mower model yth 210 xp serial no 021103c001383 year 2003
You will need the model number located on the tag the serial number is located on to look that up. With that number you can go to one of several lawnmower repair part websites like partstree.com for example. From there select the husqvarna icon, on left of next page enter the model number, select the drawing that you want for the mowing deck and look at the drawing for the belt. Take the number on the drawing for the belt and look for it on the chart to the right to get a part number and then you can call the local lawnmower repair shop for the part or you can just order it there from the website.
Jul 19, 2011 | Garden
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
I need to see a diagram of a drive belt for a
If you locate the model number of the tractor, go to www.murray.com and enter the number under support. It will bring up a Owners Manual which shows the routing as well as a lot of other good information. The model number is formatted something like this: 123456a78b substitute the numbers for your own tractor when you enter them at the Murray site. The model number is generally located on the rear of the tractor frame or somewhere under the seat.
Sep 19, 2009 | Garden
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
How to install a hotpoint electric dryer belt
Click the link to take you the belt diagrams page. Choose your brand and model number and the diagram will load. You will need the model number located on the product information tag, normally located inside the door or on top of the control panel.
http://www.repairclinic.com/0079.asp
Jun 30, 2009 | Hotpoint TDL15 Electric Dryer
My Neptune dry tub does not spin. I tried to spin it by hand and it was difficult. Can I repair this myself rather than have a repair man do it?
As you may imagine, a dryer is about the most simple household electric item there is. It is a gigantic tub that has a huge belt around it that attaches to an electric motor. The belt is rubber and subject to wear, as well as extreme heat caused by the whole process.
90% of the time its the belt, but unusually, your motor could be fried (which makes repair worthless). It's no wonder people make a living off of taking these units off the side of the road, replacing the belt for $20 and selling them on CL for $100.
You need to locate the model number and/or serial number for your unit. Also you need to open it up (which should be easy) and confirm the belt is mangled, and the motor spins fine. The belt could also just have jumped the track, and you can replace it. Replacing the belt is similar to putting a chain back on a bicycle. Usually if the belt jumps the track, it needs replacement anyway. Take the belt off/out of the way, and run the dryer to confirm the electric motor is running fine.
After that plug you model number and/or serial in google, with "replacement belt" and you should be able to find information on it.
Apr 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Adjustable belt behind the seat is broken
Yes! You absolutely can get any replacement parts. First you need the model number. The model number is located on the frame of the stroller on the right side just above the rear wheel. On some models, the model number will be found on a sewn-in labels found on the back of the seat. Once you find that, call Customer Relations, they can help. The number is 1-800-544-1108.. Good Luck.
Oct 18, 2008 | Eddie Bauer Lightweight Travel System...
Dryers Logo
19 people viewed this question
Top Dryers Experts
