Question about Wagner Spray Tech 0272903 355E CER GUN PNT TIP
Wagner power sprayer manual - Wagner Spray Tech 0272903 355E CER GUN PNT TIP
Can i thin Valpar Bond Primer no 46620 to apply with a Wagner sprayer?
If you have an airless sprayer yes , you can thin with a small amount of water or use flotrol for latex available at home depot or other box stores. If you have hvlp system no you can't. The hvlp uses a turbine wheel to compress air to around 3-5 psi. You did not say model Wagner sprayer you have. I use my Wagner to 1800-2000 psi. If the job is small you will have to consider the clean u time usually abound 30-45 minutes. Good luck
Jul 30, 2017 | Wagner Air Tools & Compressors
Need instruction manual for a "Wagner 200" sprayer
Owner's Manual - Wagner
www.wagnerspraytech.com/fileadmin/user_upload/wagner.../0525800_eng.pdf
wagner power painter 200 series manual - download - Google Docs
https://docs.google.com/document/d/.../edi
Oct 20, 2016 | Air Tools & Compressors
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Getting lots of air pressure but no paint comes out
You have old paint that is plugging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Jan 12, 2014 | Wagner SprayTech Wagner W665 Wall Perfect...
My sprayer has power and blows air but no paint comes out
you have old paint that is pluging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Aug 14, 2013 | Wagner SprayTech Paint Sprayer. Flexio 590...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
I have a wagner power painter 355E and the directions said to put oil in the 2 holes in the gun. Where are the 2 holes?
Where the raised tips of the tubing goes into the gun,
directions state ,"Apply a light coat of oil."Tip sprayer up side down (so handle is sticking up) and the underside where the two holes where the ditting dual hose go in there: This is where you put a small amount of oil into both holes and trigger the sprayer briefly
May 08, 2011 | Wagner Power Products 0154842 Medium Spray...
Wagner Spray Tech 0272903 355E CER GUN PNT TIP Logo
20 people viewed this question
Top Wagner Spray Tech Air Tools & Compressors Experts
ray gallant
Arthur Cowgill
Level 1 Expert
Tom Chichester
Are you a Wagner Spray Tech Air Tool and Compressor Expert? Answer questions, earn points and help others
