Error/fault code 250. Fisher & Paykel Aquasmart
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: fisher@paykel aquasmart WL80T65CW1 fault code245
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Posted on Nov 18, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 343 Answers
SOURCE: iw712 fisher and paykel washer has fault code 37 w...
37 is drain error..There could be electronic reasons, but the most common problem is that there is a clogged pump or something is jammed in the pump impeller... Empty the machine of water and lean back against the wall so you can get access to pump, which is clipped to the bottom of the drum..Try turning the fan and see if the pump is blocked'/jammed.....Disconnect the wires and rotate the pump motor anticlockwise...It will be prevented from turning by a small plastic latch. Unlatch and remove pump motor...Remove any detritus and refit pump motor....If the motor resistance is less than 33 ohms (230volt) or 7ohms (110volt)..the pump motor itself might be the cause of the fault code, and should be replaced......This is a very simple job for a tech...Good luck....Nomess
Posted on May 24, 2010
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Last month my aquasmart had fault code 130 payed repairman $180 to fix it now it has fault code 105 your webpage is very unhelpful knowing whats wrong with my aquasmart which is less than 5 years old
Did you look up your manual to help with the problem?
AquaSmart2 8kg - this is a link to download your manual
The good thing is that if you got Fisher & Paykel to come out, they offer a warranty on their service - so call them again and tell them the situation - they should come out for free....
Sep 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel fault codes
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 17, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Secondary Source: Pump System.
Action: Follow procedures as for Fault Code 249.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
Sep 03, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
