Question about Fisher and Paykel WA37T26G Top Load Washer
Fisher and Paykel Aquasmart
Hi. My Aquasmart WL80T65CW1 is now displaying the error/fault code 250. Could you please tell me what this means and how I can fix this problem? Thanks, much appreciated.
  • Fisher and P... Expert
  • 554 Answers
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Secondary Source: Pump System.
Action: Follow procedures as for Fault Code 249.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Posted on Dec 17, 2013
5 Suggested Answers
  • 4 Answers
SOURCE: my aquasmart fisher and paykel
Sounds like the 'lid lock' has shorted out. They're not completely waterproof and have seen pins completely blown out inside them. Should measure 73 ohms (or very close to it) across the terminals. Hope this helps.
Posted on Feb 26, 2011
  • 713 Answers
SOURCE: error code 49 on fisher and paykel 8kg aqua smart
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
Posted on May 16, 2011
rickyrt441
  • 4399 Answers
SOURCE: Replace LCD display and machine control for Fisher
Thanks for choosing FixYa and welcome to the site. Are you sure it is 24? Below is a link to the manual. The error codes are about 1/3 of the way down.
http://www.scribd.com/doc/48997386/Fisher-and-Paykel-SmartDrive-Service-manual-053-MW053-u-2010-05-31-170211-GWL-11US-FandP-service-manual
Posted on Jul 31, 2011
richroth
  • 9472 Answers
SOURCE: Fisher & Paykel error code 9
Take a look at this document.
Posted on Nov 09, 2012
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Last month my aquasmart had fault code 130 payed repairman $180 to fix it now it has fault code 105 your webpage is very unhelpful knowing whats wrong with my aquasmart which is less than 5 years old
Did you look up your manual to help with the problem?
AquaSmart2 8kg - this is a link to download your manual
The good thing is that if you got Fisher & Paykel to come out, they offer a warranty on their service - so call them again and tell them the situation - they should come out for free....
Sep 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Error 105
Try to get a Rotor position sensor as they are cheaper.
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
Error code 136 on aquasmart wl80t65cw1
If your bowl turns freely bearings are not seized,
Your rotor position sensor must be faulty & not outputting the right signal to the motor controller.
Feb 11, 2013 | Fisher and Paykel Washing Machines
My Aquasmart WL80T65D washing machine is telling me that it cannot lock the lid - but it is shut and appears to be in place.\r\n Does anyone have any suggestions for this?
Hi just read your posting.Does the machine stop and beep and show an error code in the form of lights on or an error code in an LCD display?Please reply with additional information and I am sure I can help you rectify the fault.Looking forward to your reply.
Oct 10, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
May 26, 2010 | Washing Machines
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Sep 03, 2008 | Washing Machines
Fisher and Paykel WA37T26G Top Load Washer Logo
344 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
