Question about GE XL1800 1100 Watts Microwave Oven
Glass Surface Light Lens Cracks from Halogen lights use
Just installed a 2 yr old GE Spacemaker XL 1800 Micro/hood combo - Model JVM1850SH04 - mfg. Jul 2005. Had to replace the previously broken glass light lens with a new GE replacement glass -- this is tempered glass and covers the 2 halogen bulbs that are responsible for surface and night lights. The lights work - surface and dimming for night light ... but within several hours ... the glass lens broke ... in two places ... from the heat of the halogen lights. I can get replacement lens as there is lifetime replacement ... but what's to keep it from happening again? Are the halogen lights too hot? Also, when selecting the vent fan -- it starts on high, but when scrolling through to med and low ... doesn't seem to change the fan speed ... but the vent boost does kick it up a notch. What's the cause of this? Thanks
  • Anonymous Mar 19, 2014
    The bulb which comes in the shape of circular wire is not lighting up red to indicate heat is generating.
  • GE Master
  • 9,150 Answers
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a working GE Spacemaker xl 1800, but need
Hello ,
My husdand broke our plate. Did you find one yet at a resonable price? If so email me at cshalitis@comcast.net and let me know how much you paid for it.If not you can call GE at 1-866-540-2797 and they will transfer you to the parts department and then you can order a new one. I just called ther but the parts department was closed. So call there M-F 8am-9pm.Good luck!
Mar 20, 2009 | GE Microwave Ovens
Intertnal light in spacemaker xl 1800
if there is no plate to unscrew in front of the bulb , then the only way it can be changed is to open the microwave
WARNING: HIGH VOLTAGE CAPACITOR INSIDE WILL STILL BE HOLDING HIGH VOLTAGE
if you are not familiar with this then don't attempt the repair!
then you will need a technician
electech
Oct 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
hold down the clear/off button for 3 seconds and it will unlock..
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
571 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
