Question about Toshiba 56HMX96 56" HDTV
Yellow light is blinking and blue light is on solid no picture but there is sound
ladywinn
  • 5138 Answers
SOURCE: wont turn on
Replace both of your STK ics 392-560s or 570s they maybe 392-110s if so use 392-180s call electronixs for parts 1-800-223-3205
Posted on Dec 12, 2008
  • 18 Answers
SOURCE: My toshiba 50HN67 TV won't power on.
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
  • 76 Answers
SOURCE: television turns on with yellow blinking light
check your cables, check all input sources. How old is the set?
Posted on Mar 18, 2010
  • 252 Answers
SOURCE: toshiba 62mx195 just hooked up
This is an error code that means your TV's light bulb needs changing. You can buy light bulbs for your TV online or at your nearest TV retailer or TV repair shop. Cost is about $20.00 for a new bulb.
Posted on Aug 21, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a tosiba 50hm67.
Hi mirowshimark,
Check the housing of the bulb, some unit has a reset switch in the housing of the bulb. If the bulb is not fitted right this switch is disable and make the unit gone to blinking error.
Jdvillanueva
Posted on Mar 15, 2011
Ps3 slim console powers up but no sound and no picture on tv
The issue with two discs in the tray sounds a little people peculiar and hopefully didn't damage the drive. It could be theYLOD (Yellow Light of Death) in which when you power the console on, it will be solid, then blink, then solid again.
Make sure your HDMI, Composite, or RCA cable is secure. Try different cable types just in case.
You can shipped the system back to Sony and they can exchange it for a refurbished system; check out YouTube videos for some fixes, or look for someone who fixes ps3s on Craigslist
Apr 03, 2014 | Sony Playstation 3 (PS3) Console
I have the KDF-50E2000 Sony I have replaced the bulb and I have a solid green light which isnt blinking though could the replacement bulb be the issue
So you do have a picture? Albeit dark blue? Then its the source and/or video connection that is probably the problem
Mar 18, 2014 | Sony KDF-50E2000 50" HDTV
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
My toshiba 65hm 167 wont come on
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses, don't use bigger than a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good.
Jul 01, 2012 | Toshiba 65HM167 65" Projection Television
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
56HM66 Freezes and then cycles on and off.
i have same problem ?Could you tell me if you figured the problem out? solved it thansk
Sep 30, 2009 | Toshiba 56HM66 56" Projection HDTV
Seems like only on HD inputs
U must have HD subscription to get HD channels.If u do ur HMDI have a sort or not leave it to factory setting it work ok right?
Aug 24, 2009 | Toshiba 56HM66 56" Projection HDTV
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Toshiba 56HMX96 56" HDTV Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
