Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding mower faster in reverse
Craftman riding lawn mower goes faster in reverse than forward
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 3 Answers
SOURCE: Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Posted on Jun 23, 2009
  • 376 Answers
SOURCE: i need a diagram that shows how the belt goes back
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number from under the seat...(should start with 917)... search, then scroll down to Subcomponent List to Mower Deck and there's your diagram. Hope that helped. Dwain
Posted on Jul 02, 2009
  • 33 Answers
SOURCE: model # 917.28907 craftman riding tractor. 19.5 HP
Drive belt is likely broken
Posted on Sep 10, 2009
Forward reverse
Sounds like your linkage came undone beneath your machine. Look under the carriage and move the lever back and forth, if you do not see anything attached to it, you linkage is close by just hang/laying there.
Aug 03, 2014 | Mtd Yard Machines 38-Inch 12.5 HP...
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cant get gear i to reverse on my Murry riding lawn mower
is your belt to tight? that will cause tention on the trans. and it wont go into reverse try it while its moving forward jerk it into reverse and see if it goes may be just hung between gears
Jun 29, 2013 | Mtd Garden
Reverse has got real slow, forward is slowing down to.
yea i know i did the trick i bought 2554 huq i have a lever shift i cut the platic on the reverse tp make it longer and it go much faster. now for floor pedal need make a bracket higher on pedal should make go down further and faster too.
Jul 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My craftmans 46 in cut (22 hp) tractor goes backward after I changed drive belt
If you notice how the belt leaves the motor pully and goes to the transmission, it makes a 1/2 twist? Well reverse that twist and the tractor will go in the correct direction.
Jul 03, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Riding lawn mower
belt is twisted
Nov 07, 2008 | Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
21 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
