Question about Apple iPad Complete Display - iPad 3G A1337
Camera Have camera but I can't use it
How do I use my SD card for internal storage?
There are a quite a few options.
  1. Open Terminal Emulator and check with the 'df' command, how much space is left on your partitions. Is /data or /system full?
  2. Goto system/apps/all > 'Sort by size to' find out which apps eat
    up the most space.
  3. Check if you have big size apps installed where you could change data location within the app to sdcard. Thinking of navigation apps and games. Every app where you have to download additional data to the actual app.
  4. Make sure you use the sdcard for media like photos (camera settings) music and video.
  5. CM has a built-in system to move apps to SD under settings/apps/on sdcard. Check apps that are big and you use rarely and are not interactive first. Reason: If you still use the USB feature those moved apps are not available to system anymore and are least likely to cause trouble.
  6. Another option is to use the app Foldermount. Use it to move certain locations to SD like the Download folder. Or the DCIM folder if the camera doesn't support sdcard location in settings.
  7. Use the app Link2SD which is able to move every bit from an app (including app data) to SD. It has a good overview on how much space an app really needs. You will have to create a separate partition on the SD card for that to work.
Mar 20, 2015 | Tablets & eReaders
Zeepad
Your tablet maybe faulty. I suggest you take it back to the shop where you purchased it for a warranty replacement or repair. If you try to fix it yourself you may void your warranty.
May 21, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Just brought an iview tablet and 7 hours later still won't come on oh it's 9 inches touch dual cameras
The tablet maybe faulty, return it to the supplier for a replacement or refund as it is under warranty.
May 11, 2013 | Tablets & eReaders
I don't know how to take photos on my nexus 7
The Nexus 7 does not come with a built in camera app. I guess Google figures since there is only a front-facing camera that folks won't be taking too many photos.
I recently came across an app on Google play that will allow you to launch the camera to easily take photos. You can find the Camera Launcher App for Nexus 7 on Google Play.
https://play.google.com/store/apps/details?id=com.modaco.cameralauncher&hl=en
Apr 03, 2013 | Tablets & eReaders
My zeepad screen has spiderwebed and won't register touch anylonger. is it fixable
Most places even if you have a warranty wont fix a broken screen mine has the same problem so i bought a digitized touch screen replacement on Amazon.
Feb 23, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
I just brought a he Sharper Image M18A" Tablet. Can anyone tell me if you can use Skype - as in see the other person. I know it's to do with the cameras on the tablet but when I brought this I wa
If you don't see the person you are chatting with on Skype, the issue is probably on their hardware. You do need to "Enable Video Call" from the Skype app's Menu after initiating a video call. If you aren't seen on the other party's side of the call, then it's your device settings that must be adjusted.
Does your tablet have a front-facing camera and Android version 2.3 or better? (The M18A is listed as having Android 4.0) If so, then you should be able to video chat with the Skype app. When you use the rear-facing camera, obviously there are issues with the other party seeing you.
If you have a front-facing camera, make sure that this is the default camera while the Skype app is closed. Open the default camera app and tap the icon to toggle the front camera interface (if needed). Then switch to video mode. Return to the home screen and open the Skype app. Login and start a video call. Then press Menu (in the app) and "Enable Video Call".
If this doesn't work, you may need the IP Webcam app. This is available at the Play Store. After setting the default camera, set the resolution and the frame capture rate, among other settings. Next, follow the directions for using Skype for a video call.
I hope this helps.
Nov 28, 2017 | Tablets & eReaders
My cameras don't stream video only stills
Apparently this is a big with their app and ios6. Look out for a fix, god knows when.
Sep 29, 2012 | Philips In.Sight Wireless Home Monitor...
Apple iPad Complete Display - iPad 3G A1337 Logo
18 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
