Question about Pioneer X-smc3-s Music Tap Airplay Music System black
Power supply issue for pioneer x-smc3-k
I have a pioneer x-smc3- k but can't find the power supply. Can't seem to find one anywhere on web - can anyone help? If not can someone let me know is the centre pin for the power socket positive or negative as I may have to try and make something up.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 924 Answers
Please visit the Pioneer website where you can buy a new power supply. As to what pin is positive or negative, look on the back of the case where the power supply plugs in. It's imprinted right on the case. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 22, 2013
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
Aug 18, 2011 | Pioneer DEH-P4700MP CD Player
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
I recently purchased a Pioneer SC-07 in North America(110v/60Hz) and need to convert it to use in Australia (240/50Hz) Am I able to purchase power supply to make this happen?
You need to locate a power converter. This is basically a trqansformer that will convert the 240V system into a 110V system. These are generally available anywhere where travel supplies are sold. You can also contact Pioneer and see if they have a conversion kit which would require the replacement or alteration of the internal transformer on the unit.
Dan
Nov 09, 2009 | Pioneer Audio Players & Recorders
Pioneer sd-p5073-k am in the process of replaceing the converinage chips. and cant seem to find any pico fuses anywhere on the converange board or main board there are several regular fuses on the main...
Make sure to check all the fuses with an ohm meter. Pioneer also have terrible solder joints. I used to "sweep solder" the whole convergence board. Down on the power supply you should find the pico fuses. They are pretty small in compairison to the glass fuses.
Oct 14, 2009 | Televison & Video
No power to my pioneer gm5300t
arcanum,
good day bro, from your Pioneer amp supply line do you also see a terminal marked as " System controller" ? did you also supply 12V DC to this terminal?
the standard power configuration for Pioneer Car amps would be:
12V Dc (+) supply / ( - ) supply ground / System Controller ( supplied by +12V DC)
12V ( + ) supply and The ( - ) supply ground is for stand by power, once you connect the supply through this terminal you will now have the stand by power but will not power on the unit even the LED power indicator.
System controller terminal, this should be supplied by ( + ) 12V line to power up the amp. this serves as the ON/OFF switch for the amp.
cheers,
mark
Jan 25, 2009 | Pioneer GM-5300T Car Audio Amplifier
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Apr 10, 2008 | Pioneer PRO-100 TV
PDP-502MXE dead set
hi all,
this problem lis the power supply board. be aware that pioneer pdp-502mxe has got 3 versions and all 3 power supply boards are different so before ordering a new or reconditioned one check the part number on the power board itself.
pioneer is not replacing the boards anymore.
check on ebay.co.uk
i did sold so many parts from this model.
thanks
Jan 08, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Pioneer SD-643HD5 does not power on
i had the same problem and it was the flyback transformer on the power supply board.it cost me $375 for the board.just make sure you ground yourself because the static electricity could fry it all.when unplugging the cables mark them and be careful.use a jewlers flat head scewdriver to unlock the cables.use a can of compressed air to clean off the dust.
Aug 26, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer X-smc3-s Music Tap Airplay Music System black Logo
292 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
