Duplo system 4000 error 51 - Office Equipment & Supplies
Please help me, I have a Duplo machine DP L500 and it's giving me service call E001. What would be the problem?
    ewol3i Apr 01, 2012
    main motor error..check main motor boards fuse at the back of the machine or the timing belt might be damage
  • Joseph Nov 28, 2013
    check the encoder sensor
ERROR CODE E001 DUPLO DP C120 Duplo Office Equipment Supplies
The manual is here, although it does not mention error codes.
http://www.toshiba-sa.net/Documentation%20%20Duplo/DPL-500/DPL-500_Instruction_Manual.pdf
Duplo machine DP L500 error E001 Google Search
Mar 07, 2018 | The Office Equipment & Supplies
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
Duplo DF-520 Error Code
you will find it in the operation guide. i uploaded the pdf copy here: http://www.mediafire.com/view/?7wvzv3jqwcyga1g
Jan 15, 2010 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
''my duplo dp43s have an error display as seen in the drum connot copy''
Ich brauche Softwere fuer meinen Flat bed Scaner CRIST/ Koennen Sie mir helfen?
Danke.
Gerd Rosien
Apr 03, 2009 | Duplo DP460H Copier
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Mar 19, 2009 | Duplo DP21L Copier
Got error code e104 duplo DP-460H
Jan 08, 2009 | Duplo DP460H Copier
83 people viewed this question
k24674
jasbo
jasbo
