Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a charge reading for the battery, but nothing happens when I turn the ignition-craftsman riding mower 19.5 hp
    Sergeant:
  • Craftsman Expert
  • 374 Answers
Must be sitting on the seat with blade disconnected and foot on the brake.
Posted on Jul 07, 2014
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 61 Answers
SOURCE: The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
ck for blown fuse, ck for broken wire.
Posted on Sep 06, 2009
bbreton
  • 437 Answers
SOURCE: need an ignition wiring diagram for a craftsman 14
Go to www.searspartsdirect.com. put in your model number, from under the seat and it will bring up parts list and diagrams for you.
Good day.
Posted on Oct 23, 2009
buffalonyman
  • 1865 Answers
SOURCE: mower sometimes will not start. Has new battery
You have to use a volt meter and test the ignition circuit to find out where the voltage stops. If you have 12 volts going in to and out of the switch, then switch is good
Posted on Nov 02, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
With key my riding lawn mower does not start, not even crank. Nothing happened.
Are you positive that the battery is fully charged? If so check for current reaching the starter motor. If current is there then it appears that the starter motor is no good. If no current reaches motor it is possible the ignition switch is no good.
Aug 27, 2015 | Craftsman Garden
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Nov 22, 2009 | Craftsman Garden
Have a craftsman 17.5 hp bought 7 or 8 years ago. Has "LT 1000" on its engine cover. Went to start it. Turned the key in the ignition, "nothing happened, checked battery, appear,o.k. The battery guage...
Yes, you may hear a small click when the key is placed in the run position. It is the fuel solenoid (on the carburetor) activating.
If it is a large click, then that is the pto clutch activating (as in the blades are ON) and that will not allow the engine to start.
Sometimes when a battery is low or connections at the battery are dirty, you will hear a click, that is the solenoid activating, but the battery voltage is low enough that the starter will not turn. Sometimes this condition has a chatter.
Easiest test for this situation is jump start from you automobile, or charge the battery for an hour, and see what happens from there.
Nov 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower sometimes will not start. Has new battery
Nov 02, 2009 | Craftsman Garden
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the fuse for Craftsman 17.5 HP 42 Riding Mower
I'm not sure the solenoid/relay would even energize at 10 volts (so you may not hear the clidking).
The battery is essentially dead at 10 volts -- try charging again for 4 hours or so, and then measure the voltage.
If it's not up near 12 volts, you have a dead cell and need a new battery.
May 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
27 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
