Sentry safe ms0607 factory code wont open safe
Door opened for hours. closed. now factory code wont open it. error light
  • 3 Answers
SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
Posted on Jun 08, 2008
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
How to fix a s0607
I have a Sentry Model 1610 safe with an electronic lock. Entering the factory 5 digit code gives the green proceed light but the handle won't turn and the door won't open. How can I get the door open?
Jan 30, 2014 | Sentry Safe Qe4531 Firesafe Waterresistant...
Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
Mar 22, 2009 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Jul 02, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Mar 29, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
