Question about Dryers
Maytag 3000 dryer f70 code - Dryers
SparkyNZ
  • 43 Answers
SOURCE: Just bought a Maytag 3000 washer and dryer and
Most likely the metal is aluminum or stainless and you should worry about rust unless you wash your clothes with salt-water (seawater. not gonna happen.)
If you're really concerned, I'd attempt to reach a maytag customer service person.
800-462-9824
To reach a real person press 0 at every option. Should take three times.
Posted on May 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: getting a fault code F70 on our 3000 series dryer?
F70 = Overheating sensed causing dryer stop until temperature reaches(drops) below set level - determined by manufacturer
Can be caused by different contributing factors;
1. poor airflow
2. blocked air flow screen inside tumbler
3. clogged lint screen
4. slow tumbler (low revolutions)
NOTE;
Ironically, the fourth factor has been lurking behind the popular discussions on this problem that has exhibited itself on both the whirlpool and kenmore products with the main triage to have included inspection of the electrical connections made by the installer.
These electrical connections not followed properly with accordance to '4prong' NEMA 14-30R (30amp, 2-phase circuit outlet) with separate ground and neutral posts, as exhibited in the standard dryer installation manual, will cause your tumbler to run slow. Hence, the 4th factor which caused the 'F70' code stops the dryer from operating.
Now, you have corrected the wiring as necessary and eagerly place some stuff's in there and all seems well. But as soon as you place something large and wet (HEAVY/BUNDLE), you get the error code again, Geeeezzzzz, you thought you had it!
Okay, this is what you need to do;
1. make sure your air flow is adequate by really cleaning the duct (I stuck my hand through the wall duct and scraped off old hard lint that can collect humidity & even cut my finger). Also make sure your vent hose does not have any unnecessary elbows or squiggles in it ( I had an elbow/pan type and it is not good as the heat seems to reflect too much ). KEEP IT AS SHORT AS POSSIBLE - I KNOW IT'S HARD, BUT IT IS NECESSARY.
2. Refrain from using too many softener sheets as they can & will restrict the air flow screen inside the tumbler.
3. Make sure your lint screen is clean - wash it periodically as lint particles collect moisture and this in turn raised humidity.
4. Once you have verified your electrical connections as stated earlier in this posting, run a normal cycle with towels or something of the like so as to reset the sensors in the dryer.
What my wife keeps doing is to put a back in after it's Heavy Buncle cycle (because it's not fluffy) and the dryer start up with high heat and then senses over heat and then SHE GET'S THE FAMOUS F70. In cases like this, use the damp dry selection and that works great - or better yet just use the timed dry selection with low heat.
We just have to understand that someone sat down and figured out what and how they wanted to program the computer that determines how this particular machine is going to react.
THE MAIN THING TO REMEMBER IS THAT 'F70' SEEMS TO BE THERE TO PROTECT AGAINST OVERHEATING WHICH IN TURN CAN TURN TO A FIRE HAZARD!
Posted on Mar 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: maytag 3000 dryer sopts and shows f70
1. poor airflow
NOTE;
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
blueextc3221
  • 15935 Answers
SOURCE: My Dryer Kenmore Elite HE5 show the Code F70...
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Posted on Sep 28, 2010
SOURCE: maytag 3000 series dryer fault code f22. what does
F22 is an exhaust blockage. Machine shuts off to prevent overheating and causing a fire. Check the exhaust in the back for blockage. Also clean lint screen before each load to decrease the chance of exhaust blockage
Posted on Dec 19, 2010
How to troubleshoot f70 error-code maytag dryer
Go to YouTube and ask your question there; I'd bet that a video or two will come up, thanks!
Sep 08, 2014 | Maytag Dryers
Maytag dryer 3000
i have same dryer check fuses it may have 2 fuses on your breaker that'sall my book says
Jan 10, 2014 | Maytag Dryers
Maytag 3000 series washer f70 error code only the start button beeps three times and i checked the harness model number is mhwe300vw12
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Nov 19, 2010 | Maytag Washing Machines
My maytag 3000 washer displays f70
Hi
Error code F70 means Control Unit Failure, no communication is detected between the control board & interface. You'll need to use a multimeter to check for the continuity between the Keypad and the control board. Inspect the wiring between the boards. Also check for any burnt component on the control board. You may need to replace the control board or user interface. To be sure whether the boards use a multimeter. Usually if the drum moves then user interface is bad else its the control board. hope this helps...
Daniel
Aug 28, 2010 | Washing Machines
What is f70 mean
Hi.
F70 is an electronic problem. I expained detains in the tip below.
The tip applies to whirpool built appliances like this Kenmore:
F70 and F71 are two logic board error codes that point at a communication error between the main log
Jul 27, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Maytag 3000 dryer sopts and shows f70
1. poor airflow
NOTE;
Mar 03, 2010 | Maytag Dryers
Same problem but I have a 3 week old maytag 9000 steam dryer, ran for a few minutes then turns off and display reads F 70
From everything I have read on the F70 code (can't seem to find an exact explanation of what it is) It seems like people are getting replacement dryers due to a electrical problem within the dryer control circuitry. Since it is only 3 weeks old, get it replaced. Good luck
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting a fault code F70 on our 3000 series dryer? What does it mean and how do i fix it?
1. poor airflow
NOTE;
Aug 16, 2009 | Maytag Dryers
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
