Question about Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp
Yardman mower my mower will start if i jump it off the solinode , but dies if I put it in reverse
    Sergeant:
    Champion:
  • 320 Answers
Try this. Disconnect the one single wire going to the solenoid. Use an ohm meter to see if there is 12 volts DC at this wire when you turn the key switch in the start position. If you have voltage then your solenoid is bad and needs to be replaced. If you dont have voltage, check the safety switchs for proper operation.
Posted on Nov 10, 2013
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Where is safety switch located on yardman mower?
theres a safety switch to keep you from mowing in reverse
to bypass follow shift lever down you will see two yellow wires un plug those. it will now mow in reverse
May 30, 2014 | Mtd Garden
Mtd yardman
There is probably a switch in the reverse lever that shuts of the mower. It is probably a normally open switch so when you pull the lever to reverse it pushes the switch closed killing the engine. If you unplug the switch or cut the wires going to it, it would never think it is in reverse and you could always mow.
Feb 03, 2014 | Mtd Garden
Pto won't engage after it had stalled out when in reverse
Did you take it out of reverse? You need too look closer at the linkage and at wear it gos, look for the switch on the trans mission, it going to work one of two ways positive or negative if it work from ground unplug it and see if it will work, if it doesn't try running a wire from one side of the connector to complete the circuit .
May 18, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Installing lawn mower battery
I have Yardman, MTD, 13 HP, 38", 6 speed. Put in new spark plug and new battery. Started first time and successive times (2), battery is completely drained. Can be jumped and started and will mow, but when it is shut off, there isn't any battery to restart. What would be draining the battery or not allowing it to recharge????
Sep 09, 2008 | Garden
Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp Logo
89 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
