Question about GE WVSR1060A Top Load Washer
Our WVSR1060 washer (G.E.)does not spin and you can hear and feel the pump keeps on running but never goes into the spin mode? It is only 3 years old and not used all that much. Could it be anything else but the timer switch? Thanks ! Robert.
vest6
  • 196 Answers
SOURCE: Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Posted on Jan 12, 2008
mikedurland
  • 481 Answers
SOURCE: Drain pump/motor not draining.
actually it sounds like there was or is something in the water pump (like a string or metal underwire from a bra). before replacing the water pump i would look inside it and check for foreign objects.
  1. unplug the machine, but leave other hoses connected
  2. use a butter knife or putty knife to open the front panel; at the top seam between the top panel and the front panel is 2 metal clips (about where the edges of the lid are). push these strait in to release the front panel.
  3. once the front panel is off then you should see the water pump on the right side. it has 2 large black hoses and 2 wires attached to it.
  4. take off the water pump (two 3/8 bolts) and look inside it.
some pictures borrowed from fixitnow.com, allpar.com, applianceaid.com and repairclinic.com
  • if you need to buy a new pump, then they are around $50 at repairclinic.com
  • or shop around; GE Washer Pump part # WH23X10013
  • here is a cheap one on ebay:
http://cgi.ebay.com/GE-WH23X10013-Washing-Machine-Washer-Water-Pump-Motor_W0QQitemZ170239837032QQihZ007QQcategoryZ20714QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
let me know if you get stuck
Mike
Posted on Jul 30, 2008
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Posted on Jul 22, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
On my top load washer when it goes into a spin mode everything is real wet at end of cycle and there is water running on the foorwater seems to be coming some where in the back and watwer doesn;t drain but...
Might be the seal on the pump itself. If water is coming from underneath the unit, more than likely it's the pump seal. Very common problem. You'd be better off replacing the whole pump and not just the seal. Less trouble that way.
Sep 04, 2011 | Frigidaire GLWS1349A Top Load Washer
Won't drain - no pumping sounds at all
if agitates an does not spin means is not going to drain, cause for not spinning broken door switch, look an see if you can feel it hanging or loose, if the swtich is broken it will not go into spin mode at all...........door switch is a safety device!
May 27, 2009 | Speed Queen AWS45NW Top Load Washer
Hotpoint WF430 Noisy on Spin Cycle
Hi.
It could be loose balance weight, or worn drum bearings.
Remove belt and spin drum by hand from the inside, if you can hear a rumbling noise, or any noise, or it feels stiff to turn then the bearings have failed
If it is under 5 years old, then it should still be under warrenty provided you did not buy it from Comet or Currys.
If it is balance weight, you will be able to feel movement, there is one at top and one at bottom of m/c.
Nov 23, 2008 | Hotpoint WF430 Front Load Washer
Frontloader pumps water out but won't spin
You need to replace your drive coupler. You can get the drive coupler at sears online or your local parts store. After you get the part go to sears online, Put in your model number and it will bring up a diagram to show you exactly where it is. The drive coupler goes between the motor and the transmission, It makes it spin and agitate.
Nov 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Leaking when entering the Rinse/spin cycle
what is happening is the pump is not pumping the water fast enough. your washer sounds like its a frididaire built washer. there should be a pause where the washer just stops and drains, then go into the spin cycle. so if there is water in the tub and the washer spins it will splash out from the top of the wash tub. you need to make sure the drain is clear, the drain hose is not blocked or kinked, and that the pump is functioning properly. your unit has a electric pump and even though you might hear it running the impellor my be damaged and able to pump the water fast enough.it could be as simple as removing the hose from the bottom of the tub that go's to the pump and removing a sock that found its way in. or just a bad pump. its a simple job to replace it.to get to the pump remove the 2 screws on the bottom of the front panel tilt the washer back a little and slide the panel down. you wil see the pump on the lower left. so check all the things i listed and you should find the problem..Id check the pump first it most likley the problem. good luck
Aug 04, 2007 | Kenmore 88732 Top Load Stacked Washer /...
GE WVSR1060A Top Load Washer Logo
42 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
