Question about Sub-Zero 695/S Side by Side Refrigerator
Ice bucket assembly auger
I need a picture of the auger assembly
2 Suggested Answers
professio101
  • 158 Answers
SOURCE: EC 24
It is absolutely the ice bucket. Just a different name. If you are may be getting teh error then there may be ice build up causing an obstruction on th full sensor or the bucket tracks. Make sure the area is clear of obstruction and unplug the unit for ten minutes. If everything is clear the error code should go away. Make sure you leave it unplugged for ten minutes, if you plug it in sooner you could damage the compressor.
Please give a good rating, it is very important to me. Thank you, feel free to re-contact
Posted on Aug 05, 2009
The part that turns to drop the ice out of the bucket is not rotating
If you are referring to the the ice auger assembly in a dispenser type refrigerator, that unit is driven by a motor behind the ice bucket. It may be frozen up or could be completely burned out and my need replaced.
Apr 22, 2015 | Refrigerators
Whirlpool GD5RVAXVY05 dispensing problem
yep replace the motor and she is back to normal
Mar 22, 2014 | Whirlpool Refrigerators
The parts in my ice bin have rusted or coroded and now the ice bin needs to be replaced. I can only find parts. Where can I get a whole new ice bin for my Amana sxd26vw?
The only assembly I could find was a auger and blade already assembled. Part # 12740302
Auger and Blade
For this model I am unable to find one that would be complete.
I hope this helps
At least these are the only parts the could rust in this bucket other than the flat metal plate in front.
Aug 14, 2011 | Refrigerators
Amana side x side ARS2464B circa 2000. ice maker issue - during ice dispensing mode the auger will occasionally bind up and ultimately pop the auger off track from the rear driving side and i have to keep...
I am having the exact same issue -- how did you get the auger to slip back inside the drive gear? I've been trying & trying, and my hand hurts yet no progress. Thanks.
Jan 05, 2011 | Amana ARS2464B Side by Side Refrigerator
What is a replacement part number for the ice maker tray 197D2303?
Hello BeckJeff, I believe that your fridge has the built-in ice maker and water dispenser and as such, only accumulates ice cubes in the ice maker's integral ice bin or as they call it, the ice bucket.
According to the parts list for the PSS26MSR series of refridgerators, the ice bucket and auger are supplied as a complete subassembly.
The part number is WR17X11447 and you can get ordered through any GE appliance dealer or online from several sources of your choice. If you have difficulty getting the part, you can also order it directly from searspartsdirect.com.
The approximate retail price for this should be $165.00 or less, again, depending on where you order it from.
I would suggest you confirm that this is the correct replacement part for your specific fridge model, before you order the part, so you're certain you receive exactly what you are seeking. You can call the folks at sears, toll free, to confirm the part. They can be reached at 1-800-252-1698.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker makes ice, but it won't dispense.
rmielsen and PhyllisForbe,  Your refrigerator has an auger motor that causes the ice to be dispensed when you press the ice selector on the front of the refrigerator.  You could have several possible problems that will gives you the same result.  The auger motor could be at fault. The ICE selector part of the  control panel of the front of the refrig could be at fault.  To isolate to auger or control... do the following.  Remove the ice bucket or auger assembly from the freezer. Reach into the freezer compartment where the auger assembly normally would be.  You should be able to see a "horse shoe shaped metal drive assembly" that would mesh with the auger assembly (ice bucket) to turn the cork screw shaped auger. Try and turn the auger drive assembly in rear of freezer to determine if motor armature is free.  The is somewhat difficult to do because the auger motor is high torque, slow rpm motor, but it should turn if it is good. Sometimes the auger motor will become stuck due to a water leak, inactivity, high humidity during a defrost cycle, etc.  The more possible suspect is the ICE selector assembly on the front of the refrigerator.  If any function on the refrig fountain dispenser control panel goes bad...then the ice/water control assembly will need to be replaced.  Hopes this helps you!  HandyHenry
Jan 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Have a LFX25960TT L G fridge . missing ice bucket and Auger needed to deliever ice cubes to door dispenser. Can not find a parts list of what needed service supplyer thinks that ice bucket assembly may be...
Hi, I have a lfx25960tt with a deep scratch door. Can I repair the door with some sort of metal scratch remover? Also do they sell just the door metal cover?
Mar 29, 2008 | Refrigerators
Ice Dispenser not working on PSS26SGPA Stainless Side by Side
This is a common problem with this GE and "lookalike" models. The dispensers first break the front plastic drum that holds to the auger and eventually cracks the rear circular sleeve as well. Pieces from the drum usually fall off and are even dispensed with ice ... eventually the drum is damaged enough that the auger no longer operates. The motors on these units, however, continue to operate.
You can receive the replacement parts needed to make the ice maker auger operate again by visiting the GE parts website. A usual repair will run $40-60. Unfortunately, the design of the replacement drum has not changed, so be prepared for this to happen again.
Best of Luck.
Apr 24, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
35 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
