Question about Toro Power Lawn Mower
Mower wont start changed plug still wont start checked gas line seemed okay but what is that plastic piece in the line never seen one before
Only used about ten times last year
    Sergeant:
    Champion:
  • 278 Answers
Getting a mower out of its winter slumber takes some time. Start with fresh gas, new oil, and air filter. Sometimes carbs get gummed up(varnisized gas). Donyboy73 on youtube shows how to remove Briggs n Stratton in tank carb systems and clean the parts and passages.
Posted on May 01, 2013
2 Suggested Answers
  • 51 Answers
SOURCE: laid mower on right side towards spark plug fixed
if turned on side with air filter down check to see if filter is oil soaked if so replace. also carb bowl may have oil in it. clamp fuel line remove bowl nut and drain. will smoke when starts but will clear out
Posted on Jul 18, 2010
Gas coming out of exhaust, putts, puffs of smoke, backfires, cylinder seems dry.
Did you hit something hard on the ground that stalled the mower?
Sounds like the Timing/ Keyway broke and your timing is now incorrect
Oct 29, 2015 | Honda Garden
John deere pdf manuals
Low hydraulic fluid will not prevent starting. The fuel filter shouldn't necessarily be full of fuel but if its empty my indicate lack of fuel flow. Look for debris in the fuel tank. A long skinny screw driver with a dab of grease on the end can be used to retrieve debris from bottom of tank. Remove the fuel line from the tank side of the filter and check for fuel flow. Blow into the line back into the tank then check for fuel flow. If it starts flowing then you will likely find a piece of debris in the tank. Reconnect the fuel line to the filter and remove from carb and be sure fuel is getting to carb.
If unit wont turn over. Check battery voltage: 12.6 volts or better. Be sure pto is off, unit is in neutral, and brake pedal is depressed. Check the fuse. Then with a test light check for 12 volts on the yellow or white wire on the small post of the starter solenoid with key in start position. If you have voltage to the solenoid but not to the starter then either the solenoid has a bad ground or is faulty and should be replaced. If no voltage to solenoid then you have a bad wire or switch between the fuse and solenoid. Voltage travels from fuse to ignition switch to pto switch to brake switch (to seat switch if it has four wire plug) to starter solenoid. You can use a test light to chase down where voltage stops.
Aug 24, 2014 | John Deere Tractor Starter 285 345 2243...
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Toro Mower wont stay running
The main reason why a mower starts up and then cuts off after a short period of time is because of poor air flow to the carburetor and is most likely a blockage somewhere.
First you should try this. Remove gas cap and filter then place a really thick rag over the top of the carb where the filter was and either blow into the gas tank or wrap a rag around a tapered air chuck and then place the air chuck in the gas tank (with rag fitting snug around chuck) blast it a few times and listen for bubbling, if it's bubbles then you have removed the blockage..
Take the carb off of the mower and clean the carb / jets with a thin piece of wire.
Be sure to clean the gas tank completely and the fuel line.
Check the oil level, some mowers have a low-level oil shut off.
Change the plug out with one thst is reccomended for your engine.
I wouldn't reccomend running the mower without the filter, that causes dirt and grass debri to enter the carb, fuel line and tank.
This should fix the problem, if it don't you should find a lawn mower repair service.
I hope this helps.
May 11, 2013 | Garden
I have a Honda HRR216TDA lawn mower that starts and then stops and wont stay running i have replaced the spark plug and drained the fuel tank and checked all of the lines. Could the problem be a clogged...
More along the lines of a dirty carb. Replacements run about $32 online, sometimes less. If you know what your doing, remove the carb, pull the bowl and spray clean it with carb cleaner. You will see a small plastic screw on the side of the carb holding down a black plastic piece, remove the screw and pull the plug - spray that clean also. Recommend replacing all gaskets when reinstalling the carb.
Aug 08, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Craftman 675 gold series mower set over the winter. I changed the spark plu, Filter, and gas. I cant seem to figure out why my mower wont stay running. Have any suggestions?
Hi bencasey48...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel line/s from the carburetor be sure to make a drawing to how the line/s are connected to the carburetor.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Jun 25, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
Starts easy and idles well with choke on full. Dies in run
Open the air adjustment screw a bit more. There's usually plastic piece that stops you from opening it up. I always break off the plastic.(damn engineers) It's not getting enough gas.
Aug 14, 2009 | Craftsman 25cc Gas Line Trimmer
Briggs & stratton 4hp push mower
why dose my motor cycle up & down in rpms
Jun 01, 2009 | Mtd 22" Yard Machine Push Mower
Wont start
does the machine have a safety lever you pull in before starting as i have seen them needing adjusting as it earths coil out,to further check coil you can always remove cut out lead from coil and pull starter with plug out to check spark ,hope this is of help,let us know how you get on
Apr 08, 2009 | Garden
Toro Power Lawn Mower Logo
113 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
