Question about Cell Phones
Craftsman 20890 scan tool
Can't chanhe language even after battery exchage
Good day, why craftsman diagnostic scanner show 'communication error' whenever it's scanner Nissan vehicles
PDF]Communications Could Not Be Established with Your ...
www.wisconsinvip.org/WivipPublic/PDF/.../noncom052108.pdf
May 21, 2008 - computer alerts motorists of problems with the vehicle's emission control ... tampered with and the connection to the on-board diagnostic (OBD) ... itspower from the same circuit as the cigarette lighter. ... scan tool, connected to the data link connector (DLC) under the dash, not ... General Program Questions.Missing: craftsman ‎whenever
[PDF]OBDII ABS and Airbag Scan Tool - Actron
https://actron.com/craftsman/scan-tool/.../568593-Craftsman-39853-MN...
OBDII ABS and Airbag. Scan Tool. Model 39853 .... OBD II Diagnostic Trouble Codes (DTCs) . .... Program Mode . .... Error Messages . ... Vehicle Communication Fault ...... No warranty (expressed or implied) can be made for its accuracy or completeness... Go to www.actron.com/craftsman to download the Scanning Suite.
Scan Tool Help
www.scantoolhelp.com/
A scan tool is a must for automotive diagnostic work today. ... 1996 and newervehicles (one exception is Nissan), and (2) counting the series of flashes can be confusing. ... II monitors (ready means the monitor has completed its self-check process). ... with bidirectional (two-way) communication capability and the proper ...Missing: craftsman ‎whenever
Automotive Diagnostic Scanners -- OBD-I and OBD-II
www.mikeogara.net/improve_your_car/auto_scanners/
Jan 31, 2016 | Nissan Cars & Trucks
Japanese radio
A VAG 1552 scan tool will do that for you and other things that are not in English, even KPH to MPH.
Nov 18, 2013 | Volkswagen Cars & Trucks
My husbands needs an onwers manual for Craftsman 180 degree precision laser level with laser trac mode No. 320.48253 to see what an item in there does?
I think the reason we can't find the manual for 320.48253 is because Ryobi took Craftsman to court claiming patent infringement because of one of the bases included in the Craftsman kit.The suction cup wall hanging base was to similiar to Ryobi's Airgrip base so Craftsman agreed to not sell in the USA no more.
Jan 19, 2013 | Craftsman Laser Level - Sears 180 Degree...
Website keeps coming up in Spanish and I need English in order to register the product I purchased
Go to the Google search homepage.
Type in the search key in the search box.
If your search key yields pages that can be translated by Google, it will have a 'Translate this page' link.
Click on the 'Translate this page' link.
Alternatively, go to Google's language tools page.
Enter the text you want to translate and select the language to which you want translation in the Translate section.
If you want to translate a web page, you can enter the link in the relevant box and choose the language to which you want to translate.
Choose one of the many translators available online.
Try searching the CNET downloads selection, which includes user and editorial reviews.
or
http://download.cnet.com/client-for-google-translate/3000-2279_4-10920739.html
Now you can translate web-pages, electronic mail and other documents without opening online-translation sites and buying expensive bulky programs.
hope this helps
Oct 04, 2012 | Philips Sonicare Hx9332/05 DiamondClean...
Air bag warning light remains on after complete battery drain. New battery did not extinguish the light. How do I fix this problem
That's a safety issue and even after repairing a fault, the light has to be actively turned off with a scan tool - trying tricks with the battery won't reset it.
Jul 22, 2011 | Lexus LX 450 Cars & Trucks
I have a craftsman oiless air compressor. All tools that I attach have low pressure to start. After I hold the attachment wide open for about 10 seconds, it will eventually break loose and the air flows...
check your hose or couplers for restiction --------- try exchaging with know good ones------- the rubber seal in the female coupler may be the culprit ------------torn// deteriated// comming apart & blocking off air flow....
May 25, 2011 | Craftsman Air Tools & Compressors
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
May 12, 2011 | Craftsman 2.0 amp Rotary Tool Kit
How to change language for Samsung GT-B3310
normaly it would be in your settings and you just go down the list until you find "languages" then you click on that and you'll find a list of languages available for your phone
Apr 28, 2010 | Samsung Cell Phones
Change japanese language to english
In Windows XP, you can set the UI language that the default user on the local machine (or a domain user that doesn't have a profile) will see at first first log on. It is also the UI language that is applied to system services running on local machine.
• Open Regional Options in Contol Panel
• Click on the Advanced tab
• In "Default user account settings" at the bottom of the page, check the box beside "Apply all settings to the current user account and to the default user profile"
If you go to this web site below, It shows you exactly How To.
http://www.microsoft.com/windowsxp/using/setup/winxp/yourlanguage.mspx
Feb 05, 2010 | Microsoft Windows XP Home Edition
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
