Question about RCA RP-3765 Clock Radio
Random flashing color and time
When i plug in the alarm clock i cannot make anything work. When i start pushing buttons the clock just flashes a random time and changing color. I think that i need to set the time zone and just start all over new like i just took it out of the box. I lost my manual and i know that the cd player will not open also.
  • Anonymous Jun 09, 2008
    flashing in multiple colors
  • Anonymous Dec 09, 2008
    Same problem here. It worked fine when I brought it home. Unplugged it, lost the manual and nothing
  • 4 Answers
Press color select button on the back of unit.
Posted on Feb 23, 2010
I have a RCA 3710a alarm clock I am trying to set it any solutions
Posted on Nov 22, 2009
KateSRU
Did you every get a solution. My clock is having the same problem?
dane5
Posted on Jan 02, 2008
No way to scape....
It is a internal current source problem.... I think it is a typical problem on RCA models...
For some reason there is no enough current to make the device works...
You must take your device to a technician....
Sorry...
Posted on Jan 04, 2009
Please wait keeps flashing on the screen and the clock loses time
OEM radio issues. Flashing Time. Radio Not Working... - Drive ...
www.driveaccord.net/.../51717-oem-radio-issues-flashing-time-radio-not...
Sep 20, 2010 - When I reconnected the battery, the radio does not work anymore. ... I reconnected it, turned the key and the clock is still flashing. ... Wait about three minutes or so, and reinstall the fuse. .... Please let us know what it was. .... Naviscreen comes up but I can't do anything with it because the buttons are dead.
Novelty Simpson Jukebox Alarm Clock Radio Homer ... - Fixya
www.fixya.com/search/p94498-novelty...clock/welcome_please_wait
Novelty Simpson Jukebox Alarm Clock Radio Homer Simpson Animated Jukebox Alarm ... ...welcome Please Wait" Every time I try to use any handset the screendisplays ... This keeps flashing for several minutes, and never seems to resolve.
Troubleshooting - Shop - SiriusXM Radio
Jan 16, 2016 | Audio Players & Recorders
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Set time on clock radio CS238-5G
This is the way I worked it out, as soon as you've plugged in the unit, push the MEM button for a couple of seconds then push the PLAY/PAUSE button and hour will start to flash then use the arrow buttons to change hour, then push PLAY to change minutes. Once you've finished minutes push PLAY again. Not sure about setting alarms though and if you get stuck, unplug it and start again.
Mar 26, 2014 | GPX CRCD6306DT Clock Radio
Lost manual for springfield color changing alarm clock model # 962032612V0706
I have one & I just set it. You hold down the s button until the time flashes then use the arrow buttons to set hour then push the s again to set minutes & when they flash you push the arrow button again then repeat with the alarm & date.
Tina:)
Jan 16, 2013 | Bon-Ton Springfield Color-Changing Desktop...
How do you set this atomic clock C17D2090 (WIC#628865)
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Aug 16, 2012 | Audio Players & Recorders
Setting the time on ascot projection alarm clock
Ascot AUPWE10 Projection Alarm clock. To change the main time and date. Push the Mode button until the temperature display is shown at the top. Then hold the mode button in until the the day function flashes down the bottom. Move to required field by pushing the mode button again. Adjust date and time displays using the arrow keys.
Mar 31, 2012 | Audio Players & Recorders
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Mar 26, 2011 | Audio Players & Recorders
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
Jan 17, 2011 | Audio Players & Recorders
Set clock, date, alarm on SI686 CD/ Radio / Alarm Clock with Sound Soother
Can you clarify what you need help with? To SET THE CLOCK push the "Mode" button twice. (The current time setting flashes on the display) Once it is flashing, Decrease the hours by pressing "1" Increase hours by pressing "2" Decrease minutes by pressing "3" and increase minutes by pressing "4". If no additional buttons are pressed the time will reset in about 10 seconds and the display will stop blinking.
TO SET THE DATE press the "mode" button 4 times. The current date setting will flash on the display. Decrease the date by pressing 3. Increase the date by pressing 4.
Decrease months by pressing 1. Increase the months by pressing 2. The date will reset in about 10 seconds when you stop pushing the buttons.
TO SET THE ALARM Press the "mode "button once. The display will begin to flash. Change the hours by pressing either 1 (increase) or 2 (decrease). To change the minutes, press 3 or 4. 3 decreases the minutes and 4 increases the minutes. Once you have the time reset, leave the unit alone for about 10 seconds. the display will stop blinking indicating the time has been reset.
TO ACTIVATE THE ALARM push the round button on the far right. You will see the alarm icon come on or off on the LCD display on the right side. Be sure you have set the AM or PM time correctly on the alarm time. It helps to recheck this now as I have made this mistake several times.
If you get stuck on military time and want the 12 hour clock the answer is posted on this site, as well.
Hope this helps.
Dec 25, 2010 | Sharper Image SI686 Clock Radio
RCA RP-3765 Clock Radio Logo
254 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
