Question about Refrigerators
We have a primo water dispenser, model # 900183 and the water is dispensing as one slow stream not a fast full stram of water as it use to. how do we fix that?
Had the same problem. I tried cleaning it as instruction on the copany website with bleach and water. I also unplugged it for a couple of days to see if the lines were frozen. Finally out of frustration I put my mouth on the water dispenser, pushed the button, and sucked some water out and spat it out. After that I did the same thing again but blew into it instead. I did this a couple of times and my water dispenser went from a trickle to flowing like the day I first got it. Also, you should probably clean the water dispenser after doing this, just saying.
Posted on Jan 27, 2015
5 Suggested Answers
  • 38 Answers
SOURCE: Water Dispenser on Side by Side not dispensing
It's quite possible it is plugged by hard water deposits forming in the supply line as these lines are quite small. You can check if it is plugged by shutting off the supply line and removing it. After removal turn it back on but have the end in a bucket in case the blockage is in your fridge unit. If water comes out it is in the fridge. Usually there is a screen to prevent large particles from entering. Make sure that is clean. Try these and see if that helps. If it doesn't get back to me as the trouble shooting will get more intense. I'm hoping this helps.
Posted on Sep 11, 2008
SOURCE: Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Posted on Sep 20, 2008
  • 219 Answers
SOURCE: amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Posted on Mar 19, 2009
  • 396 Answers
SOURCE: water slow to dispense from ice/water dispenser
The water line probably has a blockage. The first place to check is the on-off valve where the line to the refrigerator connects to the house water pipes. Mineral deposits often partially block these small valves.
Another possibility is within the water line in the refrigerator. I have opened up one of these lines using a length of plastic weedeater line.
Posted on Oct 09, 2009
Owners manual for Primo water dispenser 601130
Try Googling (primo)(601130)(manual) without parens.
Aug 06, 2017 | Water Dispensing & Filtration
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Primo water dispenser water stream low
check for blockage at the inlet. hose may have blockage. also if you have ability to move machine away from wall and access rear panel, you can look at the filter that the inlet hose is attached to.
Feb 12, 2015 | Washing Machines
How to fix a slow dispensing water supply on a primo model?
The screen(s) at the connection point, in the hose are probably stopped up. Clean and you will have strong water pressure.
Apr 24, 2014 | Washing Machines
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Primo water cooler
I JUST BOUGHT A PRIMO BOTTOMLOADING WATER DISPENSER AND ITS BEEN ON ALL NIGHT AND THE WATER IS WARM. I LOOKED ON THE BACK TO SEE IF THERE WAS A WAY TO TURN IT UP BUT FOUND NOTHING. PLEASE TELL ME WHAT TO DO. RNMALIN@ COMCAST.NET
Jan 06, 2012 | Primo 900172 1.0 Gallon Industrial Water...
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Refrigerators Logo
849 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
