Question about Frigidaire Affinity ATF7000E Front Load Washer
Lights keep flashing with different numbers chane over and
  • Official Brand Answer
  • 4,342 Answers
Good Morning Elizabeth - Based on the symptoms you are describing, you may either have a communication error from the main control board, faulty power supply or a potential wiring failure. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to flash. If resetting the power does not correct the issue, I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Posted on Apr 30, 2013
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
MY BRAND NEW SAMSUNG DISHWASHER HAS POWER BUT WONT START THE WASH THE WASH CYCLE THE TWO CYCLE LIGHTS JUST KEEP BLINKING
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too.
Oct 07, 2014 | Samsung DMR78AHS 6 Cycle Stainless...
Why all my lights keep flashing on my ps3 controller and my home button doesnt work
If the system is new enough, they will take the controller in for repair for free. If not, you need to get a new one. The question is, what is the model number of your controller. YES there is a difference on quality and how they are assembled.
Jun 21, 2014 | Sony Playstation 3 (PS3) Console
Dishwasher flash light blinging
Dishwasher lights flashing and blinking usually means some circuit or sensor problem > it will be helpful if you can provide the full dishwasher make and model number and specifically note which lights are blinking or flashing. Also try to turn the mains power connection to dishwasher off and back on to see if there is any difference in behaviour.
Feb 16, 2014 | Dishwashers
Wen i press the power button the tv does not comes on and the light on the power button keeps blinking red
This is usually a self diagnostic indicator. the number of flashes indicate the problem. Without knowing the model number and number of blinking lights it is hard to answer correctly. (Different manufactors have different error codes) Once you get the the number of blinks ...go to google and enter the TV model number and the words "error codes". You should have no trouble finding them.
Sep 09, 2011 | Televison & Video
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
My xbox box has 3 red lights flashing... i know there are different types of error how do i know which on i have?
after turning it on, and seeing it display 3 red lights, hold the sync up button and tap eject.
The lights will change to a different pattern. This represents a number.
The number is four digits, so you'll have to hold sync and tap eject FOUR TIMES, remembering each pattern.
Pattern numbers are as follows:
4 red lights = 0
3 red lights = 3
2 red lights = 2
1 red lights = 1
Most common ones are 0020 and 0120.
Jul 17, 2009 | Microsoft Xbox 360 Console
Umax Mirage II Flatbed scanner,3 flashing lights
Could be a SCSI termination issue. Try changing the SCSI address number on the scanner to a different one and make sure the chain is terminated properly. If there are multiple SCSI devices in the chain, disconnect all the others until you are sure the scanner is working then slowly add the other devices to the chain making sure everything works as each device is added. SCSI voodoo!
Jun 26, 2009 | Office Equipment & Supplies
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
