Central air problem
Okay. To begin with the fan in unit wasn't kicking on so I replaced capacitor in the video and also replaced contact switch which is also in video. Unit ran great. Switched on and off at set temp and no problems for past two weeks. Today all of a sudden white smoke with electrical smell started coming out of vents in house. Looked in
    New Friend:
  • 8 Answers
Try spinning the blower motor. If it does not spin freely then the motor is bad. The capacitor being bad will cause this to happen. If the capacitor was not the right microfarad that will also cause the motor to go bad. Also you can just put you nose to the blower motor and try to smell if it smells burnt
Posted on Apr 29, 2013
Master_Tech
  • 770 Answers
SOURCE: My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Posted on Jun 09, 2008
  • 14 Answers
SOURCE: Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Posted on Sep 28, 2009
  • 674 Answers
SOURCE: I have a 561c central
Sounds like you need another capacitor since it will run if you turn it by hand to get it started. If you have a clamp on ammeter check the current draw on the fan motor.
Posted on Aug 23, 2010
kingbrizzle
  • 407 Answers
SOURCE: central air conditoner outside unit
Well, the answer is yes. I have seen a bad capacitor cause a fan motor to run backwards. BUT..... After replacing the capacitor and WIRING it up the right way, everything should be fine. A lot of aftermarket condenser fan motors are reversible, so it can run counter-clockwise (CCW) or clock-wise (CW). However, most factory fan motors come one directional and on your specific unit, the air should always push out of the top. Running the unit with the fan going backwards will actually some-what do it's job, but damage other components like the compressor because it runs at higher operating pressures than what it is designed for.
Have someone else look at it! That's going to be the best advice I can give you. If they can prove that a capacitor caused the motor to permanently run backwards..... I want to know! Hope this helps and good luck with your unit.
Posted on Jun 23, 2012
  • 747 Answers
SOURCE: fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Posted on Jul 13, 2012
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Central air unit will not run
Check capacitor. If unable to check just replace with new one cost about $20 or less this is problem 90% of time.
Aug 29, 2012 | Heating & Cooling
Central air conditoner outside unit
Jun 22, 2012 | Heating & Cooling
Running or not central a/c
There is a capacitor in the fan wiring that gives it a kick start. Replace it
May 20, 2012 | Heating & Cooling
I have a Ruud Zepher Serris Central A/C & Heat unit - forced hot air. I cleaner the dirt and debris out of the outside unit put back together and now the outside unit will not start. There is power...
if you have power to the outside unit and the fan is not turning - the most likely problem is that the fan motor is bad. I would make sure the power is all OFF and then try and turn the fan blade by hand. If it's stuck and will not turn or turns 'hard' - the bearings have gone out and the only fix is to replace the motor.
If the fan blade turns freely - then you might check the capacitor (small electrical device attached by wires to the fan motor) and see if all the connections are tight and complete and that the capacitor itself is not bulged.
If it's 'bulged' that is a good indication that it's bad and that could be your only problem.
Otherwise I would either change the motor myself (if the bearings are out) or get an AC Tech to troubleshoot the system.
Hope this has helped.
Aug 05, 2011 | Ruud UAMB042 Air Conditioner
Neither A/C compressor or fan coming on in ouside unit.
The bulge is a telltale sign of a defective capacitor along with the tripped breaker. Replace it and cross your fingers.
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
My Central AC condensing unit will not start up but the air handler is running. I can engage the switching relay and the compressor and condensor fan kick in and run. I think it is either the switching...
It is the relay. THe capacitor doesn't control both the compressor and the fan. (Some use the same capacitor but it is seperated internally and usually one or the other will still start) This part should cost around $20 Buy whatever they have as long as it is rated at least as much as the one you replaced. Bigger is fine. You may have to cut off the terminals and use the screws.
Jul 04, 2008 | Heating & Cooling
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
