Question about Dryers
Hotpoint dryer Hotpoint dryer won't stay on - Dryers
  • Dryers Master
  • 8,220 Answers
The belt is probably broken. Their is a broken belt switch which keeps the main wire winding from working if the belt is broken. To check for broken belt open the door and remove the screws holding down the top. Remove the top, then take the front off and inspect that puppy. Here is my crappy video:
Posted on Apr 28, 2013
SOURCE: dryer won't stay heated. heating element works.
are you getting any codes?
Posted on May 16, 2011
  • 250 Answers
SOURCE: Malta dryer burner won't stay lit
usually a clogged vent or I've seem a coil go bad that allows it to light once but not the second time in the cycle
Posted on Feb 02, 2012
shahidkap97
  • 392 Answers
SOURCE: DRYER DOOR WON'T STAY CLOSED
the drier door became loose.go to any repair shop to fix it
Posted on Apr 07, 2012
SOURCE: dryer gas won't stay on
Bad switch.
Posted on Apr 21, 2012
SOURCE: Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Posted on Oct 27, 2012
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
Dryer won't heat up
Test the heater element first then the thermal fuses
Dec 15, 2012 | Hotpoint NVLR333EE Dryer
Dryer won't start
Fuse we 4 x 800 located on the back wall on the heater element
My home video:
Dec 09, 2012 | Hotpoint Dryers
DRYER WON'T START WHEN START BUTTON IS PRESSED.
The fuse is located on the heater element which is bolted to the back wall behind the drum.
I have several home movies and repair pix on my DIY blogpage:
PAW PAWs DIY GE HOTPOINT DRYER Repair page
Dec 02, 2012 | GE DVLR223 Dryers
Oct 27, 2012 | Hotpoint Dryers
My dryer wont come on its a hotpoint model #dlb2650bgl the timer is ticking the interior light comes on my husband put a multi-meter on the start switch and shows power what else could the problem be
The first thing I would check is the door switch. If it isn't closed the dryer should not start - although the timer would be active. If it won't tumble or heat then that is the first thing I would check and on Hotpoint that is a high failure rate.
Dec 31, 2011 | Dryers
Unit won't start when start button is pressed.
507
is the thermal limit if open due to lint or other problems the dryer will not run.
Of course it could very well be a broken door switch.
I recently worked on a Hotpoint dryer that was eating up clothing.
I took some photos. Hotpoint dryer revamp
Aug 17, 2011 | GE DVLR223 Dryers
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 09, 2011 | Hotpoint Dryers
My Hotpoint gas dryer won't relight after it has
Your gas valve electrical coils have gone bad. They are easy to replace.
Jun 21, 2011 | Hotpoint Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
