Question about Dometic Refrigerators
Dometic rm2611 Check light on, not cooling fridge or freezer
    Top Expert:
  • Dometic Master
  • 5,056 Answers
Disconnect thermistor on back let run if ok replace thermistor
Posted on May 30, 2016
  • 358 Answers
SOURCE: Dometic rm2611 quit on the road today all lights
If the fridge is complete dead (no lights no fan, no compresor,etc.) looks like there's not power in the unit.Check if theres power in the oulet if you know how , if you don't put the fridge in an oulet that you know is power , if still doing nothing probably the cord is broken or burned and the power doesn't go throught it from the oulet to the fridge.
Posted on Apr 27, 2009
tunmun
  • 413 Answers
SOURCE: dometic rm2611 not restart after cooling box normally, then warmi
Your fridge is working against outside air tempurature and any solar heating effect. To maximise the operation of your fridge allways try to park the unit so the fridge side will be in the shade. Do you have a fan to create the air circulation in the back of the fridge? There are kits available for this. I use a recovered converter fan and have it set up in the bottom of the fridge cavity below the coils and blowing straight up. This helps a lot. The kits normally come with a 80 degree F temp switch, I have a leftover toggel from some where for mine. I don't think your fridge is the problem. I don't think a new one will fix it. Your best bet is to do the kind of thing I have above and it should work better. Hopefully good enough. Good Luck
Posted on May 11, 2009
espressonist
  • 1711 Answers
SOURCE: dometic rm2611 refrigerator will not cool with on electric
We have a solution to this link that will help
http://www.fixya.com/support/r6019270-refrigerator_freezer_air_conditioner
Posted on Sep 15, 2010
kapishtech
  • 2272 Answers
SOURCE: I hav a Dometic refrigerator
The igniter may be just a bit too far from the burner to spark and light the flame. That is a physical reason. Try moving the tip of the igniter a bit closer. Once the burner has been on for a period of time the physical dimensions in the burner area may have increased to the point that the igniter can't jump the gap.
A weak igniter coil could also be the problem.
--------------- The check system light mostly comes due to faulty mother board of the rm-2611.And replacing the board solves the problem.The board which fits your dometic refrigerator is "Dinosaur Electronics Micro P-711". --------------------- Now more details about the problem and the new mother board:--- when replacement time comes install a Dinosaur Power Board. The reason for that is they have a 3 year warranty replacement and the OEM boards only have a 1 year, as well as they are usually a few dollars cheaper. But before you just replace the board make sure that the burner is clean of debris and that the propane pressure is correct and 11 to 11 1/2 water column inches. The replacement board I referred to has a wiring sheet that comes in the box and is fairly easy to understand.There are about 9 wires that hook to the board. The new one calls for an extra ground wire that is about 5 or 6 inches.----- The model of Board replacement is a micro P-711 from Dinosaur. You can get these at most RV repair shops. The regulator won't have on/ off valves for each tank but they do separate the tanks to allow one to be removed from the system so it can be refilled without any interruption in your service. One last thing on the refer, whenever you are parked for 30 minutes or more and have it turned on make sure the coach is level, or within 3 degrees of being level. To check that the coach is level purchase a omni- directional level. They are about 1 to 2 inches and are round. Put it in the freezer shelf and level the coach to that. The reason I say this is because if they are run out of level bad things can happen and in a short time. If a bad thing does happen it is usually the cooling unit that is damaged and they cost somewhere between 600.00 and 900.00 to replace. Sometimes even a bit more, and the new replacement ones just might not fit into the same hole and might need modified as well. ----------- If you want to see how the board actually look.Please click on the Link. http://www.partsfortechs.com/asapcart/micro-p711-p-6.html ---------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 26, 2010
  • 884 Answers
SOURCE: dometic rm2611 freezer works great fridge does not cool properly. noticed goop is missing in the middle bottom under the fins in fridge. will this cause air leak and ineffective cooling? can i reseal
Reseal with silicone sealant. Any idea what happened to original sealing?
Posted on Aug 07, 2012
Dometic rm2611 freezer works fine on propane but fridge doesn't cool
move temp sensor to middle of coil if same replace temp sensor
Mar 28, 2014 | Dometic Refrigerators
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
CLEANING A CONDENSOR UNIT ON A DOMETIC RM2611
If its a small unit the condensor is built inside of the cabinet or its under the fridge or you can look at the back but most of , is this a rv type of fridge?
Jan 17, 2014 | Dometic Refrigerators
RECHARCHING MY DOMETIC RM2611
Hi, it is not as simple as recharging when it comes to an RV fridge. If you have lost your pressure then you need a replacement cooling unit. A Cooling unit can normally be changed in approximately 2 hours with no specialized tools needed. Our cooling units come standard with installation instructions. Arcticold cooling units are Bran NEW not rebuilt. Our Products are unmatched in quality and performance. Check us out
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
I have a rm2611 refrigerator which has lights, no fan
There's a capacitor by or on the compressor that probalbly needs replacing. This is the cheapest route .
Jul 05, 2009 | Dometic RM2620 Refrigerator
Dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
May 10, 2009 | Refrigerators
Apr 27, 2009 | Dometic RM2620 Refrigerator
Refrigerators Logo
396 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
