Printer fault oki c7500 display hangs on startup.
    Problem Solver:
  • 5 Answers
I would start byuninstalling and reinstalling any printer program software that came with your printer. After uninstall is component drivers is done restart your computer and reinstall any software that came with the printer *install software befor you plug in your USB cable. Once everything is reinstalled plug the usb in and itshould work. If your printer is a Wifi printer follow the steps above and use the usb cable for initial installation from there you can set up your wifi and then unplug your USB cable and you should be good to go. Even if the printer is wifi it is best to set itup using a usb cable for the initial set up so that your computer recognizes your printer. Best of luck
Posted on Apr 27, 2013
How to reset he 980 fatal error on a oki 610 laser printer
The OKI 980 Fatal error is a Fuser that needs to be replaced. Replace the fuser
that being said you can replace the fuse on the fuser unit or you can do the option below that I DO NOT RECOMMEND
separate the fuser unit in half
Unravel and loosen the wires at the connector at the bottom of the fuser close to the edge so you can pull that connector out a few inches so you can get a couple of wires in there.
Insert a wire into each of the two holes on the back of that connector. 2 and 3 have wires going in, 4 and 5 don't which is the fuse. After you get the wires in the 2 holes. Make sure the wires are long enough to hang out the case. put the case back together and put the fuser in. connect the two wires together and power up the machine. As soon as you here the first motor, which is about 5 seconds into the startup, pull the wires apart. This will make the machine think that the fuser has been broken and reset the fuser life.
You can also purchase new fuse units from ebay etc and replace the fuse unit.
Sep 01, 2014 | OKI Office Equipment & Supplies
What causes a dirty background?
Copied
1) - Power ON printer while holding both the + & - buttons until "OKIUSER" message appears in LCD.
2) - Press + or - button until "ENGINE DIAG MODE" is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or - button until "NV-RAM INITIAL" is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. ...............the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Jun 10, 2014 | OKI C9600hdn Laser Printer
Oki c5300 tray 1 empty but I have paper in tray 1
there is a black sensor flag that will hang down from printer when tray is removed. verifiy it moves freely
May 06, 2014 | OKI Office Equipment & Supplies
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
OKI B6300 Laser Printer stays in a "please wait"
An initialisation fault has occured
There is a component fault with the machine.
The infomation supplied is insufficient to diagnose the fault any further
Feb 14, 2011 | OKI B6300 Laser Printer
Hello , my oki b6200 display error replace fuser E. How to clear fuser counter.
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jan 04, 2010 | OKI B6200 Laser Printer
OKI B6300 DRUM/TONER
try this:
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
What's different of oki c7200 and c7300 cartridge?
They are different and can not be interchanged
C7200 work with C7200/C7400
C7300 work with C7350/C7300/C7550/C7500
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 14, 2008 | OKI Office Equipment & Supplies
27 people viewed this question
jasbo
jasbo
