Question about Cub Cadet Super Lt-1550 Riding Mower
Lt1550 no power to the starter
Mower was running and stopped just like the key was turned. since then replaced battery and fuse by battery still nothing. when checking further i found power is not reaching the starter. any suggestions and yes the starter tests fine
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
The power goes from the key switch to seat / parking brake / to starter solenoid find where it stops and bingo
Posted on Nov 22, 2013
2 Suggested Answers
alicantecoli
  • 22306 Answers
SOURCE: I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Posted on Nov 23, 2011
Went thru mower has new battery and silinoid universal type,fuse good,I turn key but will not turn over.Bumped starter from car and motor turned over,starter and motor work so what is wrong?
Not sure of total problem but I would start by cleaning the inside of battery cables. If I understand you can jump the battery and the unit will start so the battery cables may be dirty and not getting enough power from the small battery in mower.
May 05, 2016 | Garden
Tractor will not start and only gives an initial click when key is turned
Check to see if juice is reaching the starter motor terminals and that it is grounded. If ground is ok and no juice then you will have to back trace all of the components in that circuit . Also check to make sure that all of the safety switches are in closed position when you go to start and run tractor.
Apr 01, 2016 | Garden
I was using my mower the other day, it was running fine and all of a sudden it just died. Now when I turn the the key it doesn't do anything.
Most mowers have a main power fuse or inline fuse from ignition to solonoid switch. Did you check that?
Oct 30, 2015 | Garden
Toro zero turn mower,motor quit running,replaced fuses,no start,crossed post on selnoid,engine cranked,no response with key,just clicking,battery not dead.Ingtion module bad?
Are you sure battery is not worn out? you can have power in the battery but if it does not have 12 volts the starter will not work. If that's not the problem check the starter solenoid.
Oct 24, 2015 | Toro Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What should I try next? My mower will not start.
When you turn the key, do you have 12V art the Starter?
If you do, then tap the starter with a small hammer. If it cranks, then your Starter is failing
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Will not start fuse ok battery ok they said try new starter, its ok turn key on hear click Sound sounds llik up at carberator, AMP gauge gos negetive and starter will not ingage, belt for mower is...
I would try to jump the starter. Pos cable on the starter then ground out the neg, it the starter turns over that isnt it. then check the smaller wire going to your soleniod, when you turn your key to the start position it should have power. then check to see if there is power from the battery to your soleniod then with the key turned power from the soleniod to the starter.
Aug 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet Super Lt-1550 Riding Mower Logo
303 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
