Www bostitch com
On first time use of above item Lot: 336416 0348, Cod: 8213350BWA022 2012, the air hose provided developed three holes-failed to move air to the tool. Would appreciate replacement hose soonest. Jim Corbett jcorbett@wyoming.com
Nowuser
  • 56 Answers
SOURCE: Not Recognizing login to www.ultimatesurrender.com
It could be spam as well as you account might be locked.
Posted on Dec 26, 2007
  • 13 Answers
SOURCE: companion II. The light blinks 7 times over and
7 light error refers to paddle or speed
potentiometer problem, if you feel confident taking the covers off then check that all the connections are nice and firm, also on other scooters if the paddle is not located in the neutral position when you turn the scooter on the control box will detect this and "lock out" the scooter, you can fix this using trial and error but it can be very fiddly! (yes iv had to do this before!) if all the connections seem quite solid and on the control box this would possibly suggest that either the potentiometer has failed and will need replacing (which would mean reconfiguring the paddle when its in) or there is a fault in the control box, if you dont feel comftable/cant fix this problem then obviously i would reccomend taking it to an authorised repair shop, i hope this helps you if i can be of any furthur assistance then my email is rick @ lxrixta.co.uk (remove the spaces!)
Posted on Jun 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: Bostitch N60 finish gun - air leaks out of the
There is an oring that is probably broke in half, It is referred to as a purple o ring. You can buy the whole trigger assembly but I think that just replacing the one will get you going. Let me know and I will try and help more
Posted on Jul 29, 2009
  • 2976 Answers
SOURCE: The hose dispensing hot water to the outlet
You can get good tubing at Home Depot or Lowes. Get the reinforced clear poly tubing, it will hold up better. It has webbing built in to it. You can also go for the stainless steel braided type, if they have it large enough.
Posted on Oct 12, 2009
  • 1388 Answers
SOURCE: bostitch framming gun sticking?
Most likely the headvalve is sticking. An easy fix would be to remove the head and lubricate the headvalve orings with white grease or silicone paste. The upper bumper should not have any cracks. If the problem continues replace the trigger valve (tva6). The trigger valve can be bostitch or generic sold on ebay for usually less then $20. The trigger valve has an inner valve that can stick due to swolen or hard orings.
Posted on Nov 27, 2011
How do you adjust nail pressure to make sure nail goes in all the way?? Bostitch model n60fn
Some devices have a control knob where the air connects. If not, you have to wait for pressure to build up. A drop or two of pneumatic air tool oil in the inlet pipe each day helps a lot. If your compressor is too small, the hose too long, or too many people on one hose, you can have a problem.
Sep 24, 2011 | Stanley Bostitch N88rh Framing Nailer...
Our dishwasher doesn't get the dishs clean. The Model No. is dwu6750aam- serial10607783qy
Hi and welcome to FixYa, I am Kelly
This is usually caused by either a restricted drain, (usually the problem) or larger than usual particulate under the lower wash arm tower.
The restricted drain can manifest itself:
- At the air gap at the sink (remove cover by lifting straight up then unscrew the inner cap nut and remove the particulate) NOTE the installed position of the upper cap under the nut as it will only go back together in one position)
- At the Air Gap outlet hose connections (remove hoses 2 ea. and inspect plastic tubing)
- At the sink connection. This can be either a direct plumbing connection or a garbage disposal connection. (remove the hose and inspect drain port hole for the connection.)
- At the pump outlet, (remove hose and inspect drain port)
If after doing the above you still have drain problems you will have to remove the lower wash arm and support to inspect the sump area for debris. NOTE: Pay close attention to how the lower wash arm is assembled.... they can end up being a rubitz cube!
Your illustrated parts list is here: (I will list item numbers below)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=44530&diagram_id=28395557#d28395557
Make sure that the lower wash arm (Item 2) and the upper wash arm (item 21) do not have food particulate in the holes.
There is a very very remote possiblity that the pump filter (item 6) is clogged but unless the unit sat with food particulate in it for months of no use it should not be bad.
After doing all of the above you still have the problem it is most likely the impeller (item 13) that has failed.
Thanks for choosing FixYa,
Kelly
Mar 15, 2011 | Maytag Dishwashers
I have this compressor and when I pull the switch to turn it on nothing happens. It is only about 5 months old. Is there a reset switch or somthing?
The parts schematic can be found on this page:
http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=CAP2000P-OF&serialNum=
Pop-ups have to be enabled to see the pdf file schematic that will come up with this address:
http://www.bostitch.com/catalog_images/web_pdf/IP1275-1REVA.pdf
I tink your pressure switch has failed that is item 21 of the above link. The SHOULD be a warranty repair. Item 21 : AB-9415626 0021 PRESSURE SWITCH $21.60
It is possible that the motor itself has failed but on a unit 5 months old the pressure switch is the most likely suspect.
The warrnaty Service has an "At your expense shipping" statement.
To obtain warranty service, return the product at your expense together with proof of purchase to a
Bostitch Regional or authorized warranty repair center. You may call us at 1-800-556-6696 for the
location of authorized warranty service centers in your area.
Bostitch, Inc., warrants to the original retail purchaser that this product is free from defects in
material and workmanship, and agrees to repair or replace, at Bostitch's option, any defective
product within 1 year from the date of purchase.
Maybe you live in area where you could do a carry in service.
For sure I would call them.
Kelly
Feb 23, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
Stanley bostitch double fires. It is an older stick feed. Works fine when I hold the trigger and tap the tip. But when I press the gun into the wood and pull the trigger it double fires. Gun is older, but...
You did not list your model number, however most bostitch nailers use the tva6 trigger valve. As this valve wears it will be erratic. Examine the firing pin that makes contact with trigger. If it looks worn or wabbles from side to side, then time to replace. To remove valve first remove trigger by removing roll with 3MM punch. Next remove one or two roll pins just above the valve, also 3mm. With roll pins removed air pressure will pop out valve. Be carefull because valve can come out with force, use glove or rag to catch. Parts available at www.toolpartsdirect.com, or generic valve at www.ebay.com. Good luck
Sep 18, 2010 | Stanley Bostitch Coil Framing Nailer
N64C GUN HAS A LOT OF AIR COMING OUT OF THE TRIGGER. HOW DO I FIX IT?
This can be caused by a defective o-ring or a trigger. Repalcemetn parts aer available here:
http://www.mastertoolrepair.com/bostitch-n64c-nailer-p-20071.html?osCsid=hl63q31pjjkg5c34jks4im8lh2
The trigger assembly is part # TVA6 and costs $20.
Hope this helps,
Dan
May 19, 2010 | Stanley Bostitch N80CB Coil Framing Nailer
I am trying to fill a pillow for my above ground pool-can't figure out how to use my bostitch air compressor
Plug the compressor in, turn on the start switch, one gauge reads the tank pressure, the other gauge indicates the pressure in the air hose. The dial adjusts the pressure to the air hose.
Nov 05, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Bostich framing nailer leaks air out driver hole
Generally, air leaking from the nose of the gun is caused by the vinyl headvalve/cylinder seal. It is installed on the headvalve and snugs against the cylinder. I would also check the cylinder ring supporting the cylinder that is visable when the head is removed. The cylinder ring is made of white plastic and has an oring on outside edge and seals against the cylinder with another oring. The ring tends to crack allowing air out nose. Some cylinder rings were made of metal, which is better and do not fail. Metal or plastic, check the orings there. Not to worry, these parts are not expensive and available at www.bostitch.com. enjoy
Nov 30, 2008 | Stanley Bostitch F21PL Nailer
Overfilling
Have you checked the pressure switch to ensure the rubber air hose is still attached? It is common for the air hose to come loose, or develop a small hole or crack and give the same symptoms. This may save you from having to purchase a new switch. On your model washer, the switch will be located behind the load level selector knob behind the front panel. To access, follow these steps:
1. UNPLUG the unit. There are still dangerous voltages behind the front panel with the unit shut off.
2. Remove the small panel that is angled above the washer lid and just below the operator panel.
3. Remove the cover plate under the panel by removing the series of screws holding it in place.
4. At the bottom edge on each side of the operator panel is a small screw. Remove these screws and the panel should lift up slightly, then come off, exposing the components behind it.
Look for a clear rubber hose. It should be attached to the pressure switch on a small air fitting. If not, reattach the hose and place a small zip tie around it at the point where the hose fits over the air fitting. DO NOT over-tighten, as you can break the air fitting on the switch. Just make the zip tie snug enough to keep the air hose from coming loose again.
If the air hose is in place, inspect the entire length of hose for cracks or holes. If you find any holes, I would recommend replacing the hose instead of trying to seal it. That way you avoid the possiblity of tape or sealant leaking and causing the unexpected overflow again. You can find air hose at most hardware or automotive repair stores.
If the air hose doesn't seem to be your problem, check to make sure all the electric connections are attached and making good contact on the switch. If you check all the preliminary items and everything checks good, then you may assume a pressure switch malfunction. A replacement can be found at searspartsdirect.com under the "Control Panel" heading as item number 5 (part number 134493500). I hope you find this information helpful. Let me know if you require addtional assistance.
Aug 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
