Question about Simplicity SE3 Computerized Sewing Machine
Needles break - Simplicity SE3 Computerized Sewing Machine
  • Simplicity Master
  • 7,365 Answers
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Posted on Apr 29, 2013
Thread breaks on the 2340CV Brother. Doing two needle and the right needle is breaking at the needle. Change needle and retreaded several times
Probably depends what that needle is hitting that is causing it to break. Make sure the presser foot and the needle plate hole are large enough to accommodate the twin needle. Twin needles come in different widths so if yours is too wide, it would break. However, it could be possible that your machine is slightly out of alignment that does not show up until you try to use a twin needle. Also, make sure that your thread is not causing the needle to break--could be misthreading. Some machines have separate guides and tension disks for twin threads. Those that don't have that accommodation may have more difficulty using a twin needle.
Mar 07, 2017 | Sewing Machines
Buttonhole
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Bobbin thread breaks
1. The bobbin thread is not threaded properly in the bobbin holder
2. Lint has collected in the bobbin holder
3. The bobbin is damaged and doesn't turn smoothly
Mar 13, 2015 | Sewing Machines
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
My sewing machine new home model 535 is breaking top threads all the time i have changed my needle but still breaking can you help
Needle breaks
Nov 28, 2012 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
Grinding noise and needles breaking
Needle breaks
since there is a grinding noise it would be a good idea to have the
machine checked
Sep 25, 2012 | White Sewing 1740 Mechanical Sewing...
Brother se 400 breaking needles
The needle breaks
1. The needle is incorrectly inserted
2. The needle clamp screw is loose
3. The is bent or blunt
4. The needle is too fine for the fabric being used
Feb 06, 2012 | Brother Sewing Machines
I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
here are something you might check
upper thread breaks
1.top tension to tight
2.thread to thick or to fine for needle
3.needle not inserted correctly
4.thread caught on something-spool pin, tension area
5.needle damaged
6.needle thread is not threaded properly
Needle breaks
wrong size needle for fabric
also check for lint & pieces of broke needle under the needle plate
also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
here is a tip about needle & thread
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 21, 2010 | Husqvarna Designer I
Needle breaks on my Shark Euro-pro model 361 my
Are you inserting the needle fully into clamp? You may have a bad lot of needles that werent straight. Try sewing by hand with machine to see exactly where and when needle breaks, then you might be able to solve problem.
May 04, 2009 | Euro-Pro Shark 60 - 384
Simplicity SE3 Computerized Sewing Machine Logo
47 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
