Question about Car Audio & Video
AUDI PROBLEM MY CAR IS STATING, I THINK THTA NO FUEL IS GETTING TO ENGINE FOR THE CAR TO STARTED,I THINK MY FUEL LINE BLOCK..
    Sergeant:
  • 310 Answers
Problably you have a leak in fuelpump.these are so tiny and not to see whit naked eye.so on the motor disconnect the feul line and put it in a small bottle.start the engine and see if there comes fuell,
out whit air bubbles.
check fuell filter
Posted on Jul 07, 2013
Audi a4 wont start
Petrol or diesel engine.?if diesel could be glow plugs
May 11, 2014 | 2001 Audi A4
Car started and the check engine light came on. Had previously ran fine. Died backing out of drive but restarted easily. Died again at end of street. than about a half mile it acted as if it was running...
read your code
,my advice to you is to purchase a Chilton or equivalent service manual for your vehicle,
all the necessary information to service
most any problem can be found within the pages, these manuals can be obtained
from almost any parts suppler at a reasonable cost there will be a section on how to retrieve codes and list of faults and basic repair suggestions
May 07, 2010 | 1993 Audi S4
1999 Audi A6. The car will not start, engine
Have you checked to see if there is spark at the plugs? If not, simply take out 1 plug (can be any one of them), connect the plug wire to it and just let the threads of the plug rest anywhere on the engine block. Have someone turn the motor over while you are looking at the gap on the spark plug. If your distributor is sending sufficient power, you should see a nice healthy spark! If no spark, then your problem is either bad coil, bad distributor, distributor cap, rotor, or ignition. But first things first, check to see if you are getting spark.
Mar 08, 2010 | 1999 Audi A6
Audi 1999 a4 runs rough idles up and down
I think the fuel has gone bad. it's cloging the injector ports. Try this first remove all fuel from the tank, replace the fuel filter. add 5 gallons of fuel and one bottle of fuel treatment. Run the engine for an hour
this will allow all of varnish from the bad fuel to disolve and clean the injectors. Don't be suprised
if this doesn't totally elimnate the problem chances are the plugs are fouled and need to be replaced also. Good luck
Hope this helps
Please leave feedback
Nov 29, 2009 | 1999 Audi A4
Knocking sound
Depending on what Audi says about fuel required to run your engine. Regular fuel could cause you problems in regards to engine pinging and noises. If you have your owners manual, check and see what fuel or OCTANE quality Audi states should be run through your engine.
If your not sure what I mean by Octane, I'll explain it. Octane is a rating given to a fuel, the higher the rating the better ignition within the cylinders of your engine.
Next time your at your local gas station look at your pumps, and you'll see numbers under Regular probably around 89. But the more expensive fuel has a number like 94. This is why you pay more for the fuel. This number is stating that it burns cleaner and more efficent. This may be what your car requires, that the engineers at AUDI say is required to properly run your engine.
However, make sure that your oil level in your engine isn't over filled this could also cause vehicle back fire, popping noises. But so could a lot of things, hole in your exhaust, near catalyatic converter. Hope I've given you some help.
Oct 24, 2009 | 2005 Audi A4
Audi a3 will not start after running diesel empty The rear wiper started to smoke after getting wet then not knowing what fuse to pull out we pulled out a few just to get us home car restarted and we drove...
2 problems
1 yes you need to bleed the fuel system if car has ran out off fuel
2 you need a new rear wiper motor comin fault
fuel system is self bleeding turn engine over until fuel at injectors car will start
Oct 18, 2009 | 2005 Audi A3
Audi 100s 1993 cranks doesn,t start, turns over no start. when it starts runs rough and stalls.
could very well be a faulty sensor, leaky vaccum hose, bad coil packs, needing of new fuel filter, spark plugs, wires.
Have you checked your fuel pressure to make sure it is good. You can do this with fuel pressure tester on the fuel rail.
Also check every cylinder for spark
If you don't have any spark, or very weak spark, you could have bad coil pack, module, or crank sensor.
You can remove one plug at a time, and place it back on plug wire, place it on top of engine block, have someone else turn motor over well you observe to see if there is spark.
Do you have a service or check engine light on? If so, I would have the engine codes read to pinpoint exact problem area.
Let me know if you have any questions or need further help
Aug 26, 2009 | 1993 Audi 100
Car wont start
This vehicle could also have a crankshaft sensor failing. When it dies next time, if you don't have a fuel pressure gauge available, and can't rent one from a local parts house, try tapping the bottom of the fuel tank with a block of wood. If it restarts immediately, then you may well have a fuel pump problem. Don't hit the tank so hard you bend it, and don't use a sharp object, as you may puncture the tank. If this does not work, you may need a scan tool to access the data stream to check for the crank signal necessary to make the engine start and run.
(Fuel pressure on this vehicle may be in the range of 38-60psi, do not push in the valve on the fuel rail to check for fuel pressure on a hot engine, or while spinning the engine over, you may start a fire)
Nov 10, 2008 | 1992 Buick Regal
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
