Question about Fargo HDP600 Thermal Printer
Transfer roller lift - Fargo HDP600 Thermal Printer
Results for "Transfer roller lift"
Posted on Apr 27, 2013
How i can solve the 913 service motor error lexmark sc1275 my printer?
913 Transfer Roller Error
The printer fails to completely transfer the image to the paper or does not transfer it at all.
The image transfer roll does not lift when paper is passing over it.
Suspect either the transfer roller solenoid or transfer roller motor malfunction.
The printer would have to be professionaly serviced by authorized service centre.
http://www1.lexmark.com/content/en_us/technical_support/find_service_provider.shtml
Copy and paste link above for Lexmark Service Centers.
Pre
Jan 14, 2011 | Lexmark Optra SC 1275 Laser Printer
How to solve error SC471 on my Ricoh 3800C
That is a transfer belt lift up error. The transfer belt lifts up for color and goes down for black only prints. Open right side door and check for paper stuck in the area near black rubber roller. Sometimes the belt dosen;t lift correctly. Open front door and turn knob on upper left counterclock wise to lower black transfer roller. On brown cover remove the top left screw and bottom right one (need to look on bottom side of cover) Slilde transfer unit out then back in. It is also possible the sensor inside machine is dirty.
Aug 18, 2009 | Ricoh Office Equipment & Supplies
I had a 'clean the ctd sensor' error. Cleaned it now it prints half the page in watercolors.
I had a clean the ctd sensor problem as well, as a problem with toner that I had ordered. The problem for me was that with Dell, when I called for support, the young lady on the other end of the phone although nice, was difficult to understand, and did not clearly define how you get to the ctd sensor.
After much prayer, (seriously!) I finally figured out how to get to the area I needed. With Dells instructions, I took the fuser out, thinking it was the transfer roller. The fuser is NOT the transfer roller, the transfer roller in the item that you see when you open the front entirely and look straight down. The difference is that the fuser is the first item out and has lift up blue tabs, while the transfer roller has blue tabs on each side that must click into place to hold and position the transfer roller properly. Once you get this out the ctd sensor is easily accessible, and can be cleaned. After, getting the ctd cleaned, and then replacing the bad toner cartridge, my machine once again worked.
Sherry McGregor Timberwood Mountain Realty,
Jul 09, 2009 | Dell 5110cn Laser Printer
Reset tranfer roller instructions needed
> Support & Drivers > Phaser 6300/6350 Support > Search Results Solution: Replace the Transfer Roller bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif CAUTION: Do not touch the surface of the Transfer Roller as fingerprints can cause image quality problems.
  1. Push up the latch on the front of the printer to open Door A.
  2. Squeeze the orange tabs on both sides of the Transfer Roller together, and gently lift the roller out of the printer. Dispose of the old roller as normal office waste.
  3. Remove the new Transfer Roller from its packaging.
  4. Grasp the posts on each side of the roller and insert the posts into the u-shaped guides inside the printer.
  5. Push down on the base of the orange tabs until you hear a click to lock the roller into position.
  6. Close Door A.
Looks like Roller should be detected and message should go away after you replace it.
May 28, 2009 | Xerox Phaser 6350DX Laser Printer
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
HP2420 Manual
Are you sure it's not the transfer roller that you want to replace?? this is the roller which sits directly under the toner cartridge, the fuser sits more towards the rear of the printer. I'll list instructions for removing both. Hope this helps
To remove the transfer roller -
1. Release the left end of the transfer roller by using needle-nose pliers to pinch two tabs at
the left end of the transfer roller.
2. Use the needle-nose pliers in the same manner to release the other end.
3. Lift the transfer roller out of the printer.
The left end of the transfer roller has a spring attached. At the right end of the roller, the
spring is attached to the printer rather than to the roller. As a result, the spring at the right
end remains in the printer.
To remove the fuser -
1. Remove the back cover and the I/O cover.
2. Remove the fuser-cable cover by releasing one tab on the cover, and then
rotating the back of the cover toward the center of the printer.
3. Remove the duplexer inlet guide by releasing two tabs on the guide, and then
sliding the guide toward the back of the printer.
Reinstallation tip
Make sure that both tabs snap back into place when reinstalling the duplexer inlet guide.
4. Disconnect two cables at the left, inside, of the printer.
5. Disconnect the fuser cable at the right side of the printer.
6. Remove four screws securing the fuser.
7. Tilt the fuser slightly toward the back of the printer, and then slide the fuser out of the
To remove the back cover -
1. Open the face-up delivery door all the way, and then press the door down to disengage
two door-stops.
2. Remove two screws
3. Close the face-up delivery door, and then tip the printer so that it rests on its front.
4. Open the "legal-size" cover, and then disengage one tab.
5. Lift the bottom of the cover first, and then lift the cover away from the printer.
6. Tip the printer back so that it rests on its feet.
To remove the io cover (looking at the printer from the rear, this is the small cover on the left side) -
1. Rotate the I/O cover to clear tabs at the right side of the cover.
2. Lift the cover off of the printer.
Nov 12, 2008 | Office Equipment & Supplies
Brother 9420cn message on display transfer roller not installed, appeared during printing session, cannot rectify
Replacing the transfer roller
1 Turn off the machine’s power switch.
2 Open the back cover of the machine.
3 Release the transfer roller lock levers on
the right and left-hand sides, and then lift
the levers to release the transfer roller.
4 Take out the transfer roller by gently
pulling the right-hand side up and sliding
the transfer roller to the right.
5 Put in the new transfer roller by holding
the lock levers of the transfer roller and
adjusting the angle of the transfer roller
lever shafts (both sides) to match the
transfer unit grooves. Put the transfer
roller onto the shafts and place the roller
onto the springs as shown below:
6 Push the lock levers down to lock the
transfer roller into place.
7 Close the back cover.
8 Turn the machine’s power switch back
on.
Apr 30, 2008 | Office Equipment & Supplies
Fault code SC402
Transfer roller leak error 2
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
transfer roller is not detected.
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
Fargo HDP600 Thermal Printer Logo
35 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
