Question about Da-Lite Office Equipment & Supplies
Da-lite screen won't roll back up
The screen fell from about 10 ft and the corner of the base popped off. Now i can't get it to roll back up. Help......
ripleymojica
  • 643 Answers
SOURCE: I have a home da-lite screen that is used for
take off end of track and manually release the spring.
Posted on Mar 21, 2011
  • 12 Answers
SOURCE: the scanner lid won't close
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Posted on Oct 20, 2011
vslayton705
SOURCE: My iPhone volume won't stop popping up on my
mine did that and under the "sounds" setting when I tried turning it up it would just go back to no volue. I had mine ina Bullfrog case and the plstic case was not completley sealed, once i seled the outer case it worked.
Posted on Aug 06, 2012
  • 2738 Answers
SOURCE: power window fell down, won't roll back up
I just had that happen on a 2000.
It was the window regulator.
I ordered a new one on e-bay.
Changing it involves taking the whole door apart, and you can do it yourself, if you are really "mechanical".
You would need to pay particular attention to where every nut & bolt goes, and replace exactly.
The window regulator is made of several metal pieces and some connecting wires or cables.
It is complicated if you are not familiar with it.
You will be needing to take the glass out of the door by rotating it, so you can install the new regulator.
Be blessed.
Posted on Mar 16, 2013
  • 975 Answers
SOURCE: electric window won't roll down
It's not a worm gear,just a small gear on the motor and a long
metal gear an the regulator. They are riveted in,if the door panel
cracked or a rivet came loose the gears may have slipped,have to
pull the door panel to see.
Posted on Mar 19, 2013
Power window fell down, won't roll back up
Be blessed.
Mar 16, 2013 | 2002 Chevrolet Impala
Tip
How to add songs to iPad/ iPod from YouTube and more for free
I will tell you to download YouTube videos to your iPad / iPod to an app that you can watch your saved videos and music without wifi :D
1) Go to the Apple app store on your apple product, open it up and search up the application called " Video Downloader Lite Super - Vdownload "
2) Once downloaded and open the app , you will end up at a screen which is Google
3) Go up to your bar and type in YouTube or whatever site you use (Picture below) I recommend YouTube for this because it is simple and easy
4) Type in whatever song you wan't in the search engine like you normally would and click go!
5) Once you search it up pick whatever video you wan't
6) Once you are in the video usually an ad pops up like it normally would on YouTube and with it it will say download. Don't click it or you will download the app just skip the ad and go straight to the video
7) Once at the video the same button will pop up once the video starts to play (if the button does not show up just press your finger on the screen where the video is and hold till it pops up)
8) you will come to a screen to save it and it will say file name, seeing as the song I choose was all about that base I named it "all about that base.mp4" but you can name it whatever you wan't
9) once you do that it will take you to another screen which shows the download, most of the time these upload pretty fast depending your internet speed.
10) once you are done the download it will take you to your files and you can play it from there with or without internet and you can also leave the application and do other stuff and it will play just like your music would.
I could not include a lot of pictures so I hope that I made the instructions simple but clear enough for you to understand seeing as the app is not hard to operate and usually easy enough to figure out. I found this when I was trying to download videos from YouTube to my camera roll but realized it was not the app for me but came in handy when I wanted to just sit back and listen to music
I hope you guys enjoy it and have fun ^-^
on Apr 02, 2015 | Apple iPad Tablets & eReaders
Why does my r4 card need to be back dated to work
The older R4i cards used to need to roll back the date because of a firmware bug, but if you download the newest kernels this problem's now been fixed.
If you have a fake R4i card though, it's quite likely that you won't be able to fix this problem permanently. There are hundreds of fakes on the market so this wouldn't be too surprising.
In the future, if you're looking for genuine card suppliers, if you're US/Canada based I'd recommend DSCardWorld.com and if you're UK/Europe based I'd recommend NDS-Gear.com.
Good luck! :-)
Sep 16, 2011 | Nintendo DS Lite Console
Hp pavillion converted into windows 7 ultimate from windows vista and sound does not function. downloaded sound driver for windows 7 but does not work still. please help...
Try 'roll back driver', follow these steps;
- Open Device Manger from the Windows 7 Control Panel.
- In Device Manager, locate the device that you want to roll back the driver for (her its sound driver). (Navigate through the hardware categories by clicking the > icon. You can find specific devices under these major hardware categories.)
- After finding the hardware you're rolling back the driver for, right click on the device's name or icon and click on Properties.
- In the Properties window for the device, click the Driver tab.
- On the Driver tab, click the Roll Back Driver button. (If the Roll Back Driver button is disabled, Windows 7 does not have a previous driver to roll back to so you won't be able to complete this process.)
- Click the Yes button to the "Are you sure you would like to roll back to the previously installed driver software?" question.
The previously installed driver will now be restored. You should see the Roll Back Driver button as disabled after the roll back is complete.
- Click the Close button at the bottom of the device properties screen.
- Click Yes on the System Settings Change dialog box that says "Your hardware settings have changed. You must restart your computer for these changes to take effect. Do you want to restart your computer now?"
DONE, Hope this helps,
Please rate if this solution was helpful, thanks!
Jul 18, 2011 | HP Pavilion dv6000z Notebook
Change the belt in my kenmore power-mate 120 amps...how to open it to get to where the belt is???
HELLO, JUST REPLACED THE BELT ON OUR'S. FIRST TAKE LITE LENSE OFF THERE WILL BE 2 SCREWS, REMOVE. THEN FLIP OVER POWER MITEON EACH SIDE PRY WITH 2 SCREW DRIVERS WHERE THE ARROWS ARE TO SEPERATE & THERE IT IS THE BELT. MIKE
Sep 13, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Da-Lite Cosmopolitan Screen stretch marks
unfortunately, unless you find one on ebay, you might be out of luck. sorry.
Sep 10, 2008 | Da-Lite Picture King w/Keystone Eliminator...
100 people viewed this question
Top Da-Lite Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Tony Mitri
Are you a Da-Lite Office Equipment and Supply Expert? Answer questions, earn points and help others
