Question about Crafts & Hobbies
Sawing machine The sawing machine dos not work not making stitches
Change the needle first thing. If that doesn't work, Check the length of the needle to see if the needle and the bobbin are in the correct position or alignment. also check the bobbin carriage for nicks or other rough places that may be cutting the thread.
Posted on Apr 27, 2013
How do I fix timing on sawing machine
Be sure to use a brand new needle!
Search the internet for web sites and videos regarding sewing machine timing or take it for service.
Nov 21, 2016 | Sewing Machines
Upside down stitching
Am having a difficult time picturing this. Sounds like the upper thread is creating loops under the fabric and the bobbin thread is showing on the top of the fabric.
Make sure to use a brand new needle.
Remove the thread from the machine
ALWAYS raise the presser foot and rethread the upper thread.
Make sure the thread path is correct.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin thread is threaded through the bobbin tension correctly.
Set the upper tension to the midway point (factory standard), however, this setting may need to be tweaked for your particular machine.
Bring the bobbin to the top of the project Before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Retest--begin sewing slowly.
If the upper thread is still showing on the other side of the fabric, the tension is too loose. If it is pulling the bobbin thread up to the top of the fabric, the upper tension is too tight
OR the bobbin thread tension is too loose. (CAUTION: make only small adjustments to bobbin tension--1/8 of a turn at a time!!! It also helps to mark the screw groove location with magic marker on the bobbin case BEFORE making any changes so you can back it out and return to the original setting.)
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 05, 2016 | Sewing Machines
While sawing the embroidery holder moves as well, looks like its not falling into its place correctly after embroidery, how can I fix it? Also I've self checked the machine but cant get the zi
YOUR MACHINE USES A PULSE MOTOR (SMALL MOTOR) THAT CAUSES THE NEEDLE ARM TO MOVE. IF THE MOTOR IS A PROBLEM THEN YOUR ZIGZAG STITCH AMONG OTHER STITCHES WON'T WORK. YOUR HOOP I'M NOT SURE BUT IT SOUNDS LIKE YOUR HOLDER ISN'T LOCKING WHEN YOU PUSH THE HOOPS ON. LOOK INSIDE THE HOLE WHERE YOU PUSH THE HOOP AND TOUCH ON EACH SIDE AND PLACE PRESSURE TO SEE IF THEY BOUNCE BACK. ANYWAY, YOU WILL PROBABLY NEED TO GO TO YOUR LOCAL REPAIR SHOP ON BOTH OF THESE PROBLEMS.
Nov 17, 2014 | Janome Sewing Machines
Have a brother sawing machine it just humms when i press ladel
would be something wrong with the foot petal or the motor, make sure the foot petal is snuggly connected into the plug of the machine, and if it is, then the machine needs to be checked
Mar 20, 2014 | Singer Sewing Machines
Singer 7444
Read the instruction book or take to professional,
Jan 19, 2014 | Singer 7444 Mechanical Sewing Machine
What is thread setting for sawing fabric with
I don't think you'll get it to feed on a domestic sewing machine, the foam is going to be too thick and difficult to feed through. I've used an industrial Singer 20U to sew vinyl to 1/4" foam which has a dacron layer glued to it, ie like carpet underlay thickness. This was to make replacement seat covers for ride on mowers; the Singer was strong enough to sew through both layers in a straight stitch, I could manage to overedge it on my domestic Elna but need a roller foot to stop the vinyl from sticking to the foot, and a leather needle. Even then, it wasn't easy.
Oct 10, 2013 | Brother XL-2600
Chain stopped working whilst sawing log on my new ryobi electric chainsaw. Can't find a way of rectifying, help please
As it is a new machine, you should return it for warranty repair or exchange. Make sure that the electricity source will power a working lamp. Good luck!
Dec 04, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
When saw gets hot there is a ping sound than shuts down
your clutch needs re bilt and check for kick out if it has that make shure its off
Aug 29, 2009 | Homelite Garden
Crafts & Hobbies Logo
112 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
