Question about Sony 40 KDL40EX520 LCD TV
Service menu no picture or sound after firmware update. will reset fix it? how do i get into the service menu with the remote controller?
Hi how fix the sensitve buttons o the tv because the remote control works but the tv act like crazy and jump from a chanel to other enter in menu and stuff like this
Hi, sounds like you have a late model CRT. It is possible that an OTA update has crashed firmware maybe?
If the tv can be reset to default try it. If that does not resolve the issue you may have to have the set diagnosed. It does not soung like the tuner or any of the major mainboard components. Might be fixable with a firmware update if it is modern
GOOD LUCK
Jun 16, 2015 | Televison & Video
Sound but no picture also the remote control won't work
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 09, 2015 | Televison & Video
32av502u toshiba stuck on initial setup language menu
Sounds like corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand TVs are given with screen shots illustrations.
Dec 14, 2014 | Toshiba Televison & Video
Okay I've purchased a 40 inch tv today and how do I reset everything?
From the User Manual, page 35 (page 36 in the .pdf file):
Return your settings to default values When you return picture and sound settings to their default values the
channel installation settings are not affected.
1 Press MENU on the remote control and then use [the arrow buttons] to select [Setup] > [Installation] > [Reset AV settings] > [Start now].
2 Press OK to reset the picture and sound settings.
3 Press MENU to exit.
You can download a copy of the manual from 40pfl7705dv_f7_dfu_aen.pdf http://download.p4c.philips.com/files/4/40pfl7705dv_f7/40pfl7705dv_f7_dfu_aen.pdf
You may also want to look at "Update your TV software" on the following page of the manual. Updating is not always necessary, unless the update fixes something that bothers you or provides an improvement you want (if it isn't broken, don't fix it). As of this writing, there are two sets of fixes (copied from the "Firmware Upgrade Readme File" at Software & drivers):
Software history:
Version: Problems solved.
PHL-0DA_710_0 - Momentarily looses audio after channel change.
- Time shifts one hour when changing from "Auto Clock" to
"Manual".
- Enables Philips Wireless Media Connect.
PHL-0DA_713_0 - Clock does not keep accurate time.
You do not have to apply both updates; everything is included in the latest one.
Jul 24, 2014 | Philips 40Pfl7705dv/f7 40-inch Smart...
The touchscreen menu disappears but the remote still works but, you do not know what activity your doing because you can't see anything on the screen
Hi. Try updating the firmware on the remote to resolve this issue. There is a known issue with the screens of Harmony One remote, and flashing the firmware usually fixes it. To do this, log in to the Harmony software, click "Downloads" at the top of the screen and click "Firmware."
Regards,
D
Aug 30, 2011 | Logitech LCD Touchscreen Remote Control
My harmony 520 simply stopped working.
Have you tried resetting your Logitech Harmony 520 remote by updating your remote's firmware? Firmware replacement fixes several Harmony problems.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Apr 10, 2010 | Logitech Harmony 1000 LCD Touchscreen...
LCD doesn't display anything. Removed battery and reinstalled. No success. Is there a reset process?
try these steps to fix the problem your experiencing with your LCD. most of the time this will work.
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
Jan 14, 2010 | Logitech Harmony 670 LCD Remote Control
On the screen of the Harmony520, it just saids Harmony and nothing else and i can't acsess anything. how do i get out of this?
I hope that helps.
Oct 23, 2009 | Logitech Harmony 520 LCD Remote Control
Remote greyed out on SlingPlayer
Try reseting the slingbox and running setup again.
Nov 25, 2008 | Sling Media The Slingbox Pro
Sony 40 KDL40EX520 LCD TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
