Question about Garden
How to make a four strand round braid
I need directions on how to make a four strand bound braid for a rope
  • 7,482 Answers
Hi Lois...
Go to the following webpage and learn how to make a fur strand bound braid
Bud
Posted on Apr 29, 2013
I am trying to sew a rope braid as a quilt binding... the zipper foot is too far from the rope... can I move the needle??
no
but you can get a 1/2 foot that allows the rope to be close to the needle
it is used for piping where there is a need to get the stitch close to the rope
available from any sewing machine supply shop
Jan 25, 2017 | Sewing Machines
How do I change the recoil starter?
This is how to replace the rope, to replace the assembly, simply remove the three screws and install a new one.
Gary
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Jun 14, 2011 | Craftsman Garden
The rope on my recoil stater on my tecumsa 5hp snowblower motor broke, I need to replace it.
Remove the recoil assembly from the machine, there are 3 machine screws.
Gary
May 02, 2011 | Garden
How do you rewind the starter rope spring on an Echo PB-200 Blower.
assuming the spring has not broken behind the pulley causeing this problem you should be able to just re tension the spring, hook the starter rope into the slot in the side of the pulley, this will allow you to wind the pulley ( in the direction that the engine rotates ) up, when you have turned it enough times that the spring is coil bound ( be careful as the spring will be under a great deal of tension ) release the pulley then one whole turn, now unhook the starter rope and allow the spring to recoil ( dont just let it fly back ) and wind the rope in.
Feb 04, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I CANT GET THE RECOIL APART TO PUT A NEW ROPE ON
Let me know if this is complete or if you can make suggestions to improve it.
Gary
Dec 22, 2010 | Garden
Need to replace starter cord on Tecumseh LV195EA engine for walk behind lawn mower
This is an easy one. You need a #2 phillips screwdriver, a 1/4" nutdriver or socket, a 5/16" nutdriver or socket, 84" of #4.5 braided nylon rope, scissors and a lighter or flame of some kind.
1. With the #2 phillips screwdriver, remove the 2 screws that hold the green plastic cover to the top of the engine. This is just a decorative cover.
2. With the 5/16 nutdriver, remove the 3 screws in the top of the fuel tank. Lift the tank straight up about 3/4" and then just lay it back on the rear of the mower deck.
3. The round black object on top of the motor is the starter houseing. You will find it being held on with 2 screws from the side. The 1/4 nutdriver should fit these. Remove them, and note the position of each screw and the position of the starter top. It might help to put some colored tape on the starter top and on the upper engine shroud to make sure you put it back in the same position. The starter top will come off by lifting it straight up.
4. Remove what is left of the old rope.
5. carefully wind the inner pulley (the same direction the rope will pull it) until it is tight. Then let it rotate back a little until the rope hole in the pulley lines up with the rope hole in the starter top. Use your screwdriver to hold these in place by putting it through the pulley and starter top vent holes.
6. Measure your rope out to 84inches and then cut it. Take the lighter and melt the ends of the rope to keep them from ravelling. When you melt the ends, take a paper towel or a rag and wipe the ends to form a point. This will make reinstall easier.
7. Push the rope throught the eyelet of the starter top and through the hole in the pulley and tie a figure 8 knot on the inside of the pulley. Tie the starter handle on the other end. but do not tighten this knot, you may have to untie it to lace it back through to where it goes.
8.. Hold tension on the rope and remove the screwdriver. The rope should retract into the starter top.
9.Reinstall everything in reverse order.
Nov 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Farberware model 138, base shattered. need base and internal braided cord that attaches to the pots plugs via small nuts.
You can get the base and the keepwarn element ( braided rope)on eBay under Farberware coffee parts. Ron
Jul 05, 2010 | Coffee Makers & Espresso Machines
How do i get the spring back into the recoil
I think he's trying to replace the recoil starter spring. He's having trouble getting the spring and pully and rope back into the housing. I'm trying to do the same thing with an old Green Machine weedeater and would appreciate any help.
May 10, 2010 | Craftsman 25cc Gas Line Trimmer
Kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Nov 22, 2007 | KitchenAid KEBC208 Electric Double Oven
Open Questions:
Garden Logo
203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
