Question about Dryers
Indesit IDC75 belt change
Can't get the belt back on my indesit idc75 tumble dryer
  • Dryers Master
  • 2,950 Answers
Your tumble dryer is a little different than I am accustomed to, but there are millions of dryers in the U.S. with the same sort of system. Try this. I think ( I hope) the belt goes as follows:
The small black(?) pulley should be spring loaded, so that you can either push or pull it toward you or away from you. I think the belt goes around the motor shaft first, then goes back around the black pulley, then to the drum up above. When you are done, the belt should be upside down S shaped, with the motor shaft in the bottom of the S and the black pulley in the top of the S. I cannot type an upside down S on this keypad. When you pull or push the loose pulley, it should allow the belt to slip by on one side or the other to go around the back of it.
Be blessed.
Posted on Jun 24, 2013
3 Suggested Answers
  • 314 Answers
SOURCE: how do you remove the
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Posted on Dec 21, 2010
heatman101
  • 43501 Answers
SOURCE: i have just bought an
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 10, 2010
Indesit IDC75 dryer need to know all the order in wiring on front panel timer,start,etcetera
The spade terminal wiring sequence for the timer is: White/Black to B5 // Pink/Black to A2 // Gray to A3 // Single Blue to B1 // Double Blue to B2 // Single Red to C5 // Single Black to C4.
Oct 18, 2014 | Dryers
Why when my door is open on my indesit idc75
The door switch is probably stuck in the "door closed" position. I presume the light inside also does not turn on.
Oct 05, 2014 | Dryers
Indesit idc75
2or3 screws at the back take out and push the top should come off easily
Apr 07, 2014 | Dryers
Indesit idc75
sounds like its a drum glide worn out
Jan 04, 2014 | Dryers
Indesit idc75 tumble dryer not working
Trying to help here. There was probably a switch latch at the place were you push your button to open it. When they pulled the latch it broke the contact signal plate. Now the dryer doesn't know when the door is closed. So it want start.
Aug 15, 2013 | Dryers
What's your problem? instruction manual model idc75
I dont need a manual to operate it as i have a er indoors that knows it all about anything and everything till something goes wrong then i am expected to fix it
Dec 02, 2011 | Indesit Dryers
I have an IDC75 (EU) condenser dryer. Everytime i press the start button to start drying my clothes, it will not allow me to start it and immediatley shuts off the electricity in the whole kitchen. please...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Indesit Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
Dec 21, 2010 | Indesit Dryers
I have just bought an Indesit tumble dryer model no IDC75, the dryer is working ie the drum is moving but there is no heat being generated from the machine
heatman101
Oct 10, 2010 | Indesit Dryers
Dryers Logo
1,396 people viewed this question
Top Dryers Experts
