Question about Plumbing
Kohler bathroom faucet cartridge 77809AA - Plumbing
SOURCE: dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Posted on Mar 14, 2009
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
  • 94 Answers
SOURCE: trying to put new cartridge in my moen bathroom
shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
How to fix a locked-up hot water handle?
Hello friend,
ALL of these taps (im english !!!) faucets ? have a LIFETIME guarantee. see http://www.faucet.com/kohler-k-8201-4-polished-chrome-taboret-centerset-bathroom-faucet-includes-metal-pop-up-drain-assembly/f230779#warranty-info
'To obtain warranty service, contact Kohler Co. either through your Dealer or Plumbing Contractor or calling 1-800-4-KOHLER or by writing: Kohler Co., Attn: Customer Service Department Kohler, Wisconsin 53044 U.S.A'
Worth a try !!! even if only to find out how to get them apart !!!!
Sep 14, 2014 | Kohler K-8211-4-CB Taboret Widespread...
Kohler Bathroom Faucet
Those parts are not sold individually. You will need to replace the whole unit.
Jun 08, 2013 | Plumbing
One of the handles on my Kohler faucet does not turn (at all). The model is very similar to the Kohler Memoirs centerset faucet I've noticed that the other bathroom faucet (dual sinks) is beginning to be...
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
Sep 08, 2010 | Kohler Memoirs Centerset Lavatory Faucet...
When hot water is turned on the pipes make this vibrating sound. i have two sinks in my bathroom. When I turn the hot water on on sink 2 the pipes vibrate. Sink 1 is fine.
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
Aug 22, 2010 | Kohler Plumbing
Water leaks around the hot water handle when I turn on the water.
what valve do you have. most likely you will need to replace the cartridges
Jul 28, 2010 | Kohler Forte Two Handle Centerset Lavatory...
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Dripping faucet
Mar 14, 2009 | Kohler Model 102704A: FortĀ® Centerset...
Plumbing Logo
236 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
